First time to use steroids HELP
  • First time to use steroids HELP
    Hi everyone. I am new in the forum. I am 20 years old. It's my third year to workout. i am 5.74 ft and 161 lbs. When i started I was only 110 lbs.
    I'd want to start a cycle of steroids. I read that the best for beginner is Dianabol. I just want to use it in a moderate way. My questions are:
    -It's correct to start with this product?
    -The cycle is for 4/6 weeks?
    -What is the suggested dosage for me? (based on my height and weight?)
    -What products I have to take after the cycle?
    -If I use it in a moderate way there are side effects?
    -GenezaMeds.com is a good site to buy?
    Thanks for the answers
    I would do some more research before starting any AAS. You are still young and can put on some very nice permanent gains/foundation at your age without any juice. Train hard, eat right and get adequate rest and you will get some amazing gains that will make your gains from a cycle that much better. Dianabol only option is not the best way to go but as you do more research you will find out why.
    If you are stuck on doing a cycle I would say Test would be the best best but I would say gain naturally for a while before going that way.
        Pls dont start orals because it seems to be the easy way. You will damage your inner organs especially your liver. If you want to go the route of roids, be sure it will be a lifetime choice. I think almost everyone in this forum will tell you not to start under the age of 25 because your body is able to make the best naturally permanent gains at your current age. Dont mess your system up with roids now, if you want to anyways do some more research about test enanthate.
          The Show,
          Both these guys are absolutely correct. I know this isn't what you want to hear, but it's the truth brother. Please listen to these guys, we all here I'm sure do feel the same way. You have so much Natural Testosterone running through your body right now that you should be able to reach any goal you choose. DO NOT USE ORALS BY THEMSELVES, you need to run Testosterone also. That D-bol will shut you down in one week and you will be left with 0 Testosterone in your body!!!
          Chat Box Talk And Rules
            Thanks you for your advices. I will follow.
            Thanks again to all
              Yeah 25 is the min age and so many people I know
              (Including myself) say I'll just cycle once to help me along the way and next ting you know your on you 5,6,7,8,9 cycle. So really look into what your about to do.
              Haters are always gonna hate. Your better being hated on than the one doing the hating love life live it.
                Although Dbol is usually found in pill form it can also be found as an injectable.
                The use of Dianabol is currently popular for jumpstarting a bulking cycle, and thus seeing immediate results from the outset of the cycle. For this reason it’s often stacked with longer acting injectables such as Testosterone Cypionate or Enanthate, and Deca-Durabolin. The rationale here with this is that the Dbol will give the user a rapid buildup of weight and strength, and those gains can be compounded when the injectables begin to produce results. This is typically done for the first 2-6 weeks of a cycle, with 4 weeks being the most typical time span.
