Originally posted by sixpaw
View Post
A Guide to Safe Injection Technique
This is a sticky topic.
Hi i have a whole box of 1cc insulin syringes 28g 1/2 here ... i know this isn't what you recommend but if i was patient would they work or is the needle just not long enough ... also i see you use GP alot does that stand for Geneza Pharma... just curious thanks for all the good info so far ... i've been ready your ask sam section .... probably going with test enanthate and clomid or Nolvadex maybe dbol for my first cycle ... also i notice that there is some test enanthate up on there for 7 buck and 20 bucks and a flux of prices up to 52 ... is that based on quality and i you pay for what you get type thing or is it just personal choice? thanksLast edited by sixpaw; 06-18-2012, 12:36 AM.
Leave a comment:
You don't want to mainline steroids. I've heard of people doing this. Man that sure will f-ck you up.
Leave a comment:
you shouldnt see blood, if you do take it out...i started 3 threads with videos in the health/wellness section that should help you with all major injection sites..if you have any further questions after watching them PM meOriginally posted by BillyBuilder View Postwhen you pull back on the plunger before administration, how often have you seen blood in the barrel? Iv injected many times and when i learned to inject i never learend to draw back. I still don't and have never had problems (knock on would). and what would happen if you did pump into your blood?
Leave a comment:
Leave a comment:
By taking the guesswork out of the most daunting aspect of first time AAS use, you'll save some guys serious grief. Good lookin' out bro!
Leave a comment:
for what its worth, i've used almost nothing but GP in the last 2 to 3 yrs. my lat spread looks the way it does, because of 1 diet, 2 training and 3 GP GEAR.Originally posted by kidbare View Posthello. thanks for the reply. i have read the tip about heating the oil some. from your suggestions here i sounds like a 23g pin might be a good ''inbetween'' place to start. since i am unsure where i will be ordering from. i could not locate a reviews section on this board. am i missing it? i ask because a lot of the reviews i have read other places on GP are not too favorable.
but yea, a 23g is fine
Leave a comment:
I never started doing it yet. Just doing my search an im happy i came across this it open my eye an mind on this subject with pins. Thanks for your time you take to type this for newbie like me.
Leave a comment:
Leave a comment:
this is a good question. it all depends on what you're personally comfortable with and what oil you're using. but yes, anyone can use a 25g pin no matter what level they are at. as i mentioned in the article, i use them for everything, but a 23g is pretty standanrd. i dont personally know anyone who uses a 22g. you may be surprise as how much work it is to push oil through a needle with any pin. it'll be a lot different than an allergy shot. it can take a lot of effort with a 25g if the oil is thick. it can be done though. if you are here at JM, you may be considering using gear from our sponsor. lets take GP gear...it is very very thin. one might think it even looks like water in the vial. a 25 g will be ideal. very little work. now lets take omnadren...it is a very thick human grade oil. i have used a 25g pin but it took forever! if i were to use it again, i would get a 23g pin. so the short answer is, try both! see what you think for yourself.Originally posted by kidbare View Posthello, if i my jump in.... i am new here. most of the research i have read up to this point seemed to suggest a 22GA 1 1/2'' for injections. i am no stranger at all to shots ( allergy injections throughout early life and some adult life ) but i have nevr given myself injections. obviously i would rather use a 25 as opposed to a 22. is the 25 ok for a first cycle person looking to do test e at 250mg 2X per week? i have read that it may be difficult to get it through the needle with such a small guage. thanks!!
also a trick that works well to make it easier, is to heat the oil a little. i use a hair drier. some warm their vials in warm water. just remember that you dont want water to contaminate anything. i use a hair drier to warm the oil in the barrel. just be careful not to heat it too much or you can burn yourself.
Leave a comment:
Leave a comment:
Me personally..one and done. Pins and syringe combos are inexpensive and once I open it I figure the chance of contamination is not worth the risk.(having had an infection or two) No matter how careful you are...sometimes shit happensOriginally posted by hackleech View Posti got a question for how many injections do u use the same multi use syringe before u replace it?
Leave a comment:
you got it. a 20g pin will making drawing so fast compared to the 25! wow, you must sit there all day with that thing!!Originally posted by Aln80017thanks again Sam!
I use a 25g to draw and shoot, I never thought about getting a larger pin to draw. heh
Leave a comment:
Leave a comment:
