ACTUAL CUTTING CYCLE if one exists
  • ACTUAL CUTTING CYCLE if one exists
    Heres one from my old Bro Basskiller, that I have kept and refer too for years, Its basic but shows you how to do it
    Clen/T3 Cutting Cycle
    This is a 6 week Clen-T3 Cutting Cycle:
    Clen is taken 1 week on - one week off:
    As in my experience it is more effective this way:
    A mild anabolic of 50mg of Winstrol ED, Anavar at 40mg ED or Test Prop at 50mg ED or 100mg EOD is recommended to preserve muscle lose and fight of a catabolic state that T3 can cause. You could also use longer ester testosterone, but they will take much longer to kick in to be effective.
    Start T3 at 50mcg as any lower makes no sense since your body should be producing between 20mcg-25mcg daily naturally... Clen doses use as a guideline along with the T3 doses, everyone has different tolerances for both, but this is was very effective for me...
    You can use a simple ECA stack during your off weeks in the place of Clen if you want to help with the fat burning progress... Your diet should be fairly high in protein, moderate carbs with no sugars and moderate fat intake... You may also want to add a source of EFA's like a flax seen oil to your diet during this time... Also Clen is known to cause allot of muscle cramping... Also I start off week three at the same dose I finished with at the end of week one... Again all depends on your tolerance to the drug, you may want to start a little lower for a few days before going right back to your maximum dose.
    Drink more water along with taking extra minerals and potassium and 2-3 grams ED of the amino acid L-Taurine is recommended if cramping is really a problem... Also take your Clen and T3 in two divided doses during the day... Also to give you an idea my daily calorie intake was probably about 1,000 to 1,200 lower then normal
    for this entire time...
    BTW when I ran this cycle I was running 900mg week of Test Cyp as my only anabolic right at the end of a bulking cycle... My results is I went from a chunky, but thick as a bull 240lbs to a fairly hard 212lbs or so in only 6 weeks... Again adjust the doses to fit your tolerance...
    At these doses you will be sweating and hot all day long... Plan on losing some muscle mass even with the anabolics...
    Day 1 Clen 60mcg -- T3 50mcg
    Day 2 Clen 60mcg -- T3 50mcg
    Day 3 Clen 80mcg -- T3 75mcg
    Day 4 Clen 100mcg - T3 75mcg
    Day 5 Clen 100mcg - T3 75mcg
    Day 6 Clen 120mcg - T3 100mcg
    Day 7 Clen 120mcg - T3 100mcg
    Day 8 Clen off - T3 125mcg
    Day 9 Clen off - T3 125mcg
    Day10 Clen off - T3 125mcg
    Day11 Clen off - T3 125mcg
    Day12 Clen off - T3 125mcg
    Day13 Clen off - T3 125mcg
    Day14 Clen off - T3 125mcg
    Day15 Clen 120mcg - T3 125mcg
    Day16 Clen 120mcg - T3 125mcg
    Day17 Clen 120mcg - T3 125mcg
    Day18 Clen 120mcg - T3 125mcg
    Day19 Clen 120mcg - T3 125mcg
    Day20 Clen 120mcg - T3 125mcg
    Day21 Clen 120mcg - T3 125mcg
    Day22 Clen off - T3 125mcg
    Day23 Clen off - T3 125mcg
    Day24 Clen off - T3 125mcg
    Day25 Clen off - T3 125mcg
    Day26 Clen off - T3 125mcg
    Day27 Clen off - T3 125mcg
    Day28 Clen off - T3 100mcg
    Day29 Clen 120mcg - T3 100mcg
    Day30 Clen 120mcg - T3 100mcg
    Day31 Clen 120mcg - T3 75mcg
    Day32 Clen 120mcg - T3 75mcg
    Day33 Clen 120mcg - T3 75mcg
    Day34 Clen 120mcg - T3 50mcg
    Day35 Clen 120mcg - T3 50mcg
    Day36 Clen off - T3 50mcg
    Day37 Clen off - T3 50mcg
    Day38 Clen off - T3 25mcg
    Day39 Clen off - T3 25mcg
    Day40 Clen off - T3 25mcg
    Day41 Clen off - T3 25mcg
    Day42 Clen off - T3 25mcg
    The mind is the greatest weapon
    T3 Cytomel should not be taken for long periods of time with no breaks in-between. It really should be taken on a time on-time off cycle. For example; 2weeks of Clen/T3 then one week off…If you use T3 for more than 3 weeks with no signifigant off time you risk a permanent thyroid insufficiency. Since it can have an effect on thyroid function, a check with a physician is highly recommended to ensure your thyroids are healthy to start with; before beginning Clenbuterol and T3 Cytomel usage. (very important)Much like the dosage of your Clenbuterol, T3 Cytomel should also be started at lower level and slowly increased. The most common starting dosage is 25 mcgs (espically if using AAS along with). Every two days add 25mcg, not to exceed a daily dose of 100mcg.(Remember kids…T3=muscle loss at higher dosages so I say keep it low and please just try to cycle during your AAS cycle). At the end of three weeks, or less depending on your planned cycle, you need to taper it off gradually as well.
    Clenbuterol usage not only results in fat being metabolized, but it also can aid in protein synthesis/uptake. If you are not already injesting 1 gram per lb of body weight of protein you should start when on a Clen/T3 cycle.
    At the same time- If you just remain patient, never subcribe to the notion that MORE is better- just start low and increase slow and small. All these stories I hear of people with jittery etc- I use all kinds of ephedrine, stims and these and never in my 20 years of doing so have I had an issue, because I respect the compounds.
