Bold/T3
  • Bold/T3
    I have been on 400mg of bold for three weeks and starting t3/Clen . I have take t3 before at 150 mg and did wonders. I bulked up this winter and now want to get ready for my first contest. Also wanted to keep stack simple. I ate a fuck ton when I was bulking and got kinda soft. Contest is in May. I also read somewhere you can take 1 mg per lb of body weight. I have read it several places. Thanks a ton.
    Red Bull
    sigpic
    Are you trying to figure out how to take t3? I dont see a clear cut question here
      Yes. I have seen the stack of clen/t3 where ya start low and ramp up. 125clen/100t3. Then i have seen where they talk about higher levels of t3. I was thinking about trying that way. Wanted to know what y'all thought.
      sigpic
        http://juicedmuscle.com/showthread.p...-My-Take-On-T3
        im doing this way right now with clen 2 on and 2 off. starting clen at 40mcg/day and going up to 120mcg/day over the 2 weeks
          I was wanting to run higher t3. I got up to, 19 bf. That is why i started bold to get in my system to lower chance of muscle lose. But i will sacrifice so muscle to get my bf down.
          sigpic
            here is an oldy but a goody; (2008)
            T3 and the Modern Athlete
            By: TJ
            * The following article is for educational purposes and not meant to replace a doctor's advice, the author in no way means to encourage the use of any medicine without a prescription from your doctor. As always this article is the property of the author (TJ) and permission should be requested from him before using elsewhere.
            So you've decided to use T3 to help you shed fat now that you've read up on it and gotten past the nay sayers who expound the ills of shutting down your body’s own production of natural thyroid. Wonderful, T3 when used correctly can be a great addition to any diet and cardio plan. Read that again boys and girls, IN ADDITION TO ANY DIET AND CARDIO PLAN!!! If you've turned to T3 because you think it's a magic pill that will allow you to eat like crap and still lose weight you've been listening to the wrong advice. Can you lose weight/fat while using T3 and still eating junk food, unfortunately yes to a degree. I say unfortunately because this fact often leads people to do just that, it starts with a cheat meal that turns to a cheat day, which eventually has the athlete eating whatever and whenever they want and still they lose some weight. So what's wrong with this if the eventual out come, weight loss that is, is reached? The first problem is the weight you are losing may not be fat if your eating like crap, the second is what happens when you stop the T3 cycle and your metabolism is suppressed temporarily, if you were eating sloppy during the T3 usage your most likely to keep following that pattern and the combination of a slow metabolism combined with sloppy eating results in rebound weight gain. So in the end what have you really accomplished outside of being able to eat what you want with out getting any fatter for a month or so? And that's if you’re lucky and the rebound weight gain doesn't push you past your starting weight!!!
            Now that I have your attention and you know what NOT to do, let's concentrate on what TO do. Just like any other chemical we find in our arsenal, T3 can and is used in a variety of ways when it comes to dosage and length of cycle, both for cutting and bulking. This article will deal with cutting use only. There are some who prefer to "hit it hard" and go high dosage with a quick taper down at the end losing a great amount of weight in a short time, but this way tends to eat as much muscle as fat in my experience and you end up looking basically the same as when you began, except that you weigh less and are smaller. There are those who like to use the same dosage throughout the cycle with no taper up or down figuring if your metabolism is going to be sluggish anyhow why waste the days using it at a low dosage when you could be burning more fat on those days. Then there are those who slowly taper up, maintain the highest dosage for a set time and then slowly taper down. It's the last group I'll concentrate on here, as this is the system that has shown it's best overall results with those I've worked with.
            Let's start with the dosage, T3 is a very individual drug, when it comes to dosage I've seen guys use as high as 250-300mcg/day and others as low as 25mcg/day where both athletes lost fat and reached their goals. As a rule I start everyone (and for now I'm dealing with men I'll pen an article on women’s usage in the future) at 25mcg/day. I usually base the time of the cycle on their individual weight loss goals, if it's a smaller amount I'll go 3 weeks tops, if it's a lot of weight to lose we'll go 4, 5 and sometimes 6 weeks. I generally don’t go over 6 weeks with anyone, as T3 tends to stop working in most people after that amount of time. I’d rather they run 4 weeks cycles with 2 weeks off where they use an ECA stack or Clen during the break to continue to lose fat, then run another 4 week cycle. So the 1st 3 days in this cycle would be 25mcg/day, then the 2nd 3-day period is 50mcg/day, etc. The typical 21-day cycle will look like this:
            Days 1-3.................. 25mcg/day
            Days 4-6...................50mcg/day
            Days 7-9...................75mcg/day
            Days 10-12................100mcg/day
            Days 13-15................75mcg/day
            Days 16-18................50mcg/day
            Days 19-21................25mcg/day
            As you can see the dosage is increased by 25mcg/day every 4th day until the maximum dosage is reached for the subject, in this case 100mcg/day, then lowered the by the same 25mcg/day increments every 4th day until the end of the cycle. Given that most of the people I've worked with have tried everything else and are still considerably overweight when they start, the full 4-week cycle is often used instead of the 21-day cycle. The one I've used lately with the most success is as follow, remember the jumps are still 25mcg/day but this time you increase/decrease the dosage every 4 days:
            Days 1-4...................25mcg/day
            Days 5-8...................50 "
            Days 9-12.................75 "
            Days 13-16...............100 "
            Days 17-20...............75 "
            Days 21-24...............50 "
            Days 25-28...............25 "
            Note: You could also do the 3-day increase/decrease and hold the maximum dosage of 100mcg/day for days 10-19, but some find 100mcg/day makes them too uncomfortably warm and they sweat too much, especially during the warmer months.
            There you have it, simple yet effective. If you remember to supplement your diet with plenty of protein (which every lifter should anyhow), eat a clean calorie controlled diet, drink 1-2 gallons of water per day and to take a mild steroid cycle to minimize muscle loss you should be able to see rapid fat loss with this cycle. I should also mention that some people like to stack T3 with Clenbuterol for even better results.
              Thank you sir. That helps. I have taken high amounts but the first two days on 25mg my metablizen is hauling ass.
              sigpic
                I hear ya. I ve been upto 150-175mcg (maby even 200 shh)
                stuff works well, I combined it with clen - which I feel to some extent but not really getting that "Clen" feel?? I went as high as 200mcg clen and still no more than if I had a few cups of coffee?
                as a matter of fact I still had 2-3 cups of coffee per day while using it?
                I believe their r a few of us here on JM which clen just does not do it for us.
                (sent u a PM -xtra info)
                ODB
