Out of answers
  • Out of answers
    I am running the same test that I have ran before, but this time I have little to no sex drive and I am only noticing small peaks of "that feeling" you get when at the mid point of your cycle. The only thing that I am doing different is running Adex instead of the OTC stuff and I started with a epie and andro PH while I was looking for the real. I was only on that for 2.5weeks. I even bumped it up to 1.25ml per week. Should I just yell BUNK! and find something else quickly? Keep in mind that when I was running the PH's my drive was fine.
    Never mistake kindness for weakness...
    how many cycles have you run? my sex drive was INSANE my first 2 cycles, and has never been the same since. not that its bad now, but it was ridiculous at the beginning
      I agree with PW. My first cycle was ridiculous as far as my libido goes. Just the thought of sex had me standing at attention in a matter of seconds. It has never been that way sinse.
        this is my second injectable test cycle. I have run plenty of PH cycles and some solo winny cycles (stupid I know) but that is it. I'm telling you I'm in bad shape here. I'm forcing myself to bone just to maintain a good name!
          How much adex are you using? Lowering your estrogen levels too much could cause this also.
            could be this^^ , or u could get some andactim (DHT gel for ur Manhood), HCG may help also.
            u could also up ur test dose.
              I've run PH cycles before and they have CRUSHED my sex drive into non exixtence. That may be the problem if you didn't PCT properly from them. I can't speak much to the test question though as I will be doing my first one whenever our sponsor opens back up, but now I'm curious as to how old you are JB? The reason I ask is I'm 44 and definitely don't want my drive going south on me.
                I'm mid cycle and I can still call the solider to duty LOL and have as much sex as I want I just don't feel the desire to do it at all. The adex was the direction I was going because I had read up alot about estro levels and how you need them to both build muscle and increase sex drive. I have leaned out more than anything no mass gains so yeah I'm leaning towards the overage of Adex. The problem is that it is liquid Adex that you take with a droper and I really cant tell you the acurate dose. I have been using .5ml EOD. I was thinking of going to .5 E4thD to see a change. Thoughts.
                  give it a shot
                    I am going to start by allowing myself to clear out the Adex by not taking it till i notice symptons coming on and then I will start the E4D dose if needed. I have contacted my source to see if they can give me a better idea on milligrams to dropper ratio
                      it should be labeled mg/ml, so just use a syringe to measure out the ml ull looking for. alot of them just give you a non marked dropper thats absolutely useless
                        no my dropper is marked. I just dont know what the concentration is. I was only doing .5 on the dropper EOD. That shit works too good lol. I wonder if I would be better off just using Nolvadex?
                          Jelly I'm on test and HCG and adex and after starting my adex mine went down. I was taking it e3d and now just twice a wk. the day after my shots .5mg pills. It's not like not having it but it's better than it was.
                          Knowledge Is Power
                            if its adex(anastrazole), id be willing to bet money its 1 mg/ml
                              Thats what I may do then. I have been off of it for five days now and "the tingling in my dingeling" is coming back LOL. I am going to wait at least another week to start it up again. I have started a liver support to help drop the Adex levels in my body. I will continue to keep you all posted on my new Adex product and effects. I'll tell you one thing it killed my cycle performance! When i find the right dose it will be great.
