Homebrew help
  • #16
    Originally posted by stiphy View Post
    let me know how it goes nympholvr. Just placed an order for raws today. cant wait to get started.
    Will do for sure... Would anyone be interested in me posting pics of the process I know there are already alot of recipes with pics already so no worries if you guys dont want more..
    Looking for friends in the bodybuilding arena.... Perfection is not attainable, its just my goal.
    • #17
      you can never have to many. I would love to see more. The better educated i get before i give it a shot the less chance I have of screwing it up.
      • #18
        another easy conversion;
        Convert Steroid Powders into an Injectable form
        A how to version of converting steroid powders into an injectable form. This steroid conversion is meant for the longer estered anabolic steroids such as deca durabolin, testosterone enanthate, trenbolone enanthate etc. This is a very easy conversion method. Please keep your area as sterile as possible, The more sterile you are when converting steroids, the less chance you have for a bacteria related abscess.
        Also. Please make sure you know the laws in your country pertaining to steroids.
        Step1
        Weigh out 10 grams of steroid powders
        This will create 40mls at 250/ml of powders such as deca, tren enanthate, test enanthate
        Step 2
        Add Solvents and oil to the Beaker
        24.50 mls of oil (preferred is grape seed oil)
        0.80mls BA = benzyl alcohol
        7.20mls BB = benzyl benzoate
        Using this Anabolic Steroid Calculator for your calulations will ease the process; http://www.basskilleronline.com/ster...alculator.html
        Step 3
        Add Your steroid powder to the Beaker containing oil and solvents
        Step 4
        Stir steroid powder into solution
        Step 5
        Using a pan slightly filled with water. Warm the solution until everything becomes clear
        Step 6
        Attach 22guage needle to the whatman syringe filter
        Step 7
        Swab the top of the vial with alcohol wipes to sterilze it
        Step 8
        Insert the 20guage syringe filtered needle into the septum of the vial (the rubber piece)
        Step 9
        Insert the second need;e tip into the septum to vent the pressure that will build from injecting the solution into the vial
        Step 10
        Draw up the warmed solution. Having it warmed will speed up the process and make it easier to filter
        Step 11
        Attach the barrel of the syring to the whatman syringe filter. push the solution through the whatman syringe filter into the sterile vial. Use constant pressure. It will only trickle. Be sure not to apply immense pressure as that will split the syringe filter and you will have a mess everywhere
        Step 12
        Detach the syringe barrel from the whatman syringe filter and draw up another 10mls of your steroid solution. Reattach to the syring filter and filter it into the new sterile vial. .
        If using 10ml vials, Just repeat steps 8 thru 12 filtering 10mls of the solution in each of the vials
        Final product Your choice as to which size vial you use. You will end up with either One 40ml vial or Two 20ml vials or Four 10mls vials at 250mg/ml
