Hello I am really interested in making my own gear. I know this site has many people way smarter than I that can chime in their experience. Please this is for research so anyone who has experience with raw powder conversions into safe useable gear would be greatly appreciated. If this is not cool to discuss please forgive me and I apologize in advance. Thanks again...
Homebrew help
actually, weve been over a few of them on this site, heres cyp
http://juicedmuscle.com/showthread.p...ghlight=recipePain is just weakness leaving the body
Originally posted by Raws n Morefor around 300$ you can easily make 40x 10 ml test e @ 250mg/mlLooking for friends in the bodybuilding arena.... Perfection is not attainable, its just my goal.
Originally posted by stiphy View Postcan you post a recipe for test e?
Here's a Steroid Powder recipe for making 50ml of 250mg/ml Testosterone Enanthate, you could follow same steps but use Testosterone Cypionate powder. Conversion done by Kitchen Chemist
First thing first, Clean off area you are workin on with rubbing alchol and a cloth. Then go wash hands with antibacterial soap. Set up all ingredients needed, for this experiment it'll be the following:
12.5g Testosterone Enanthate "Powder"
7.5ml of Benzyl Benzoate
2.5ml of Benzyl Alcohol
29.5ml of your favourite Oil
20CC Syringe
12CC Syringe
2 18ga needles, 1 25ga Needle
.45 Sterile Whatman Filter
50ml Sterile Vial
50ml Vial
Electric Scale
Rubbing Alchol/Paper Towels
Now that all materials are in place, take out scale (i like to calibrate it every use) and put on unsterile 50ml vial on scale and zero out.
Get your weight scale
I like to melt down the powder to a liquid to find out exactly how much displacement it takes up. Start by Drawing up 15ml of liquid, make sure there are no airbubbles and plunger is exactly in line with 15ml hatch mark. Now slowly squirt test enanthate into vial until scale says 12.5 grams. For me this is usually exactly 12.7-12.8ml so 1g has a little more then 1 mL displacement but for little experiments it's not gonna matter, just use 1ml per gram displacement rule. Also add the 7.5ml of bb and 2.5ml of ba.
Now add 27.5ml of the 29.5ml of oil into the vial to make total volume of oil/ba/bb/hormone to be 50 mL. Leave the 2ml of oil in syringe for later use.
Now take out sterile 50ml vial and wipe stopper with rubbing alchol. Put 18ga needle and 25ga needle through stopper, and attach whatman filter to the 18ga needle stuck in vial.
Now open up 20ml syringe and attach 18ga needle and draw up 20ml of unfiltered gear. You will need to repeat this step another 2 times, last time only drawing up 10ml.
Once you've filtered all 50ml and vial is totally empty, take the last 2ml you had saved and run it through the filter to get all gear out of it and only leave plain oil in the filter. i left 25ga pin in, there is more than 50ml i had 10ml left over that i wanted to refilter from last cycle.
nice golden color, compared to the amber EQ i made in last thread.
Now put vial in oven at 200 degrees F, and bake for 15 minutes. Some repeat this step more than once but i never have and not had a problem. There you go, save yourself a ton of cash and MAKE YOUR OWN GEAR!"GYM + JUICE"
