I don't know what is different today, but no matter what I do I am just drawling air and no test into my needle. I tried 4 different needles and I even tried a different bottle of test same problem. Could it be barometric pressure related? We have been in a tornado watch.
needle problems
That question is perplexing.........if the tip of the pin is in the oil it is theoretically impossible to pull air out of the oil. If it was one pin and barell would say u have a leak somewhere outside of the tip of the pin. If the oil viscosity happens to be thicker because of barometric pressure or temp then all you should get is a negative pull on the plunger and no oil pulling into the tube. Strange dude......MODERN DAY GUNSLINGER
