Can someone tell me do they both bring the same sides..? (acne, blurred vision, headaches...etc). My last PCT I took Clomid and it was horrible hot flashes, acne, blurry vision, felt like a visually impaired woman. If so should I expect the same sides from Nolva this time around?
Nolva & Clomid
the reason you got the sides is usually due to the dramatic change in hormone levels...i would try adjusting (lowering in your case) the dose..i personally dont use clomid due to the effects it seems to have on peopleOriginally posted by mega0888 View PostCan someone tell me do they both bring the same sides..? (acne, blurred vision, headaches...etc). My last PCT I took Clomid and it was horrible hot flashes, acne, blurry vision, felt like a visually impaired woman. If so should I expect the same sides from Nolva this time around?Satisfaction Is the Death of Desire
I was in the same boat. I would say adjust the dose you are taking in. It seemed to work for me, for a short while. The blurred vision really got me hard. I had to switch to Nolva. I respond better to it. Clomid, I used because it was accessable to me relatively easily. I suggest not using the easy road. Dont be a product of your enviorment in this case.Originally posted by ds222 View Postthe reason you got the sides is usually due to the dramatic change in hormone levels...i would try adjusting (lowering in your case) the dose..i personally dont use clomid due to the effects it seems to have on peopleAirborne. Air Assault. Pathfinder.
Follow Me.
True, true! Nolva gets a "pussy" rap from some people. But if you get the dosage right, it's effective.Originally posted by AIRBORNE View PostClomid, I used because it was accessable to me relatively easily. I suggest not using the easy road. Dont be a product of your enviorment in this case.
Also, it won't promote the bad cholesterol levels that A-Dex can. My cholesterol is 160 at 47 years old. That's a good number.
Get regular blood work and see what works for you.
use nolva unless you used a nor-19 compound such as decca or tren then use clomid take the nolva depending on how long and how much gear you took but my normal pct with nolva is wk1 50mgs wk2 40mgs wk3 40mgs wk4-5 20 mgs it works great for me and I always like to add hcg to my cycles to to make it easier to come off.take the hcg 250iu every 5 days during your cycle right up till when you take the nolva it will help your body still produce test on its own during the cycle so it wont shut down completely.you can make it 500iu every 5 days if your really high on the test.
