Gen Shi Labs Cut Stack 150
  • Gen Shi Labs Cut Stack 150
    Anyone tried "Gen Shi Labs Cut Stack 150" thinking about trying it out on my next order. Just wondering if anyone else has tried it. Whats the feedback.
    Thanks
    AMAZING STACK. The best compounds, IMO. Very worth it.
      2ml eod is all you need. If you're not a 250lbs monster or gear junkie
        extra gear
        would you add anything else like extra test? How is it as far as pinning?
        sigpic
          ya i think the mix should have an extra 50 mg of test.. if u take it at 1mg ed ur only getting 350 test.. i would up that for sure. the rest is cool.. alot of people love this mix i think im going to try it in the spring.. so if u go for it make sure to post results :P gl
            I'd add in a bit more Test as well.
              I was doing it this way. 1ml cut stack and 1ml of testovis eod. Good cycle for me it was. My first with tren. Next time it will be 2ml of cut stack eod.
                What were your gains like?
                  I went from 198lbs and 14% BF to 215 lbs and 11% in 10 weeks. I had some problems with acne, but nothing too serious.
                  big1
                    Very nice results bro!
                      Thanx! It can be better. My diet was not 100% spot on. I'm sure with same amount of gear and better diet i can have a lot better results. I need to work on my appetite, a lot!
                        Very nice gains man!
                        Was this with the genshi cut stack?
                          so could a person get by with just cut stack 150? is a little extra test needed?
                            If you did 1ml each day that would equal to 350mg of Test, Tren, Mast. I would add in a bit extra Test. 1ml of GP Test or something will give you 600mg a week of Test, 350mg of Tren and Mast. Which is good.
                            If you did 2ml EOD that would be roughly 400mg of each per week. I'd still up the Test a bit.
                            But honestly, with that combo, even with 350mg-400mg of Test... You will gain very nicely! Tren is like nothing else. It will transform you.
                              Yeah, but tren can shut you down like nothing else. So, maybe more test or add some proviron.
                              Silver Back
                              - No, it was diamont cut stack and italian human grade testosterone propionate - testovis.
