Second cycle
  • Second cycle
    So it would be the following:
    Weeks 1-12 GP Test E 500
    Weeks 1-4 GP Oral Tren 750mg (sweet spot for many)
    Weeks 10-14 GP Tbol 50mg
    Weeks 1-12 GP adex .50 mg every other day
    Weeks 1-4 10-14 Liv52 3 tables a day
    Anything else should i add to bring sides from Oral Tren to a minimum?
    abzlove
    I see where ur coming from bro....but its not an injectable Tren....its an Oral ...if i notice any sides i will stop it immediately...
    abzlove
      Looks Ok. I would just add Deca. Use the oral tren or Tbol to kickstart and that's it.
        I'd keep a second cycle very simple, test and dbol, or test and deca. Simple sometimes is better, see how you respond to two compounds before adding more. Eat right, train hard and grow big.
          Anabolic hit the Nail on the Head - K.I.S.S (keep it simple)
            I don't really like the oral while the test clears.
            Becareful with the oral tren!
            Add some hcG!!!!!!!!!!!!!
              Yeah, you guys are right! I'll pass on Tren for now...
              So i'm thinking about followings:
              Weeks 1-12 GP Proviron 50mg (sweet spot for many)
              Anything else should add or take out?
                I think that looks good. Just like the girl in your avatar.
                You should make good gains. A lot try to run too much too soon when its not necessary. Save it for when its needed. If you can gain 30lbs with 2 different items and 30lbs with 5 items why not just keep it simple with the 2? Your body can only put on so much at a given time no matter how much you take.
                  I would add some hcg. The organon prgenyl is good stuff.
                    u man 750mcg rite? lol
                      sounds like a solid cycle bud.. only thing i would do diff..is take the tbol first and end with the tren.. but that sounds delicious gl
                        I concur, and so will your balls.
                          I dont know how to mix hcg with water...and if one pack of 5000U would be enough for the cycle?
                            well most take 250 ius twice a week, so 500 a week. so that would put 5000 ius at 10 weeks
                              u may run a little short, especially if u choose to do a last final "boost shot" of 1000ius (3-4 days b4 PCT starting).
                              I am completing a 12 week run and have very little left (started week 2 + may have missed 1 or 2 also)
                              ODB
