Hey, Ronnie - I've read and re-read your blogs and posts about helios before contacting ya. The one thing that I still don't quite understand is how many shots per day.
For example:
I wanna pin my lower back "love handles" and my lower belly. I don't know how sensitive I will be to this compound so I'm thinking I should keep the dosage moderate to low obviously.
My question is - do I pin ALL those spots each day?? Or one spot per day working my way around the waist-line such as this
Day 1 - right "love handle" w/ .5 cc's
Day 2 - left "love handle" w/ .5 cc's
Day 3 - left lower belly w/ .5 cc's
Day 4 - right lower belly w/ .5 cc's
and so on....
Or would I pin ALL those spots daily? If daily - would I still use .5 cc's on each spot??
Also - as far as sterility is concerned - should I use a fresh pin on each spot or can I use the same pin for all 4 locations?
I hope I've made sense in this explanation.
Thank you so much for your time and information, buddy. VERY much appreciated - very valuable
Bro,
You always pin left and right at the same day. Meaning left and right "love handle" and left and right lower belly the other day.
Start pinning low 1/10 of a ml ( one part) from a U100 insulinsyringe. Clean the injectionspots with ethanol or betadine. Start low and work your dose up. Very important too, is the massage of the fatspots under/with a hot shower to increase fatloss/breakdown.
Dieting is ver important too. If you use AAS you know that hardening androgenics like masteron and winstrol wil speed up the process, if you use gear that is able to convert to estrogen (aromatisation) its harder to loose fat and keep musclemass, in that case you need an aromatase inhibitor.
Most people use Helios alone, caffeine and by example ECA will add to the effect so be carefull.
The dose depends therefore on your expirience, bodyweight, sex and tolerance. You should feel okay, a bit wired but not the much. Trembling hands are normal. An increased hartrate should be kept under control. Take it in the morning to enable a healthy sleep
After rereading my answer: if you tolerate bigger amounts of course you can pin both bellie and lovehandles etc the same day, just depends on previous named precautions
For example:
and so on....
Bro,
