changes in HRT TRT
  • changes in HRT TRT
    Where as Testosterones where used for HRT and HCG for restart now new protocols are used. Let me know what you ( the members) think.
    Source
    Aging Male. 2004 Dec;7(4):319-24.
    Testosterone therapy--what, when and to whom?
    Jockenhövel F.
    Abstract
    Testosterone therapy has been used for more than 60 years in the treatment of male hypogonadism. The classical forms of hypogonadism are comprised of primary testicular failure or insufficient testicular stimulation due to the lack of pituitary gonadotropins. Typical causes of primary hypogonadism are Klinefelter's syndrome, anorchia or acquired disturbances of testicular function. Secondary hypogonadism is characterized by insufficient production of pituitary gonadotropins, due either to pituitary failure or defects at the hypothalamic level. It is unequivocally accepted in clinical practice that any male with inadequately low testosterone production for his age will require androgen therapy. In addition to the classical forms of hypogonadism, the past decade of research has clearly demonstrated that, with increasing age, many men will suffer from decreasing testosterone production. About 15-25% of men over the age of 50 years will experience serum testosterone levels well below the threshold considered normal for men between 20 and 40 years of age. Studies substituting testosterone in elderly men with low serum testosterone have shown that men with clinical symptoms identical to the symptomatology of classical hypogonadism will benefit most from such therapy. Therefore, it is the general consensus to treat men with age-related hypogonadism only when clinical symptoms are present that can be potentially corrected by testosterone administration. Until recently, intramuscular injections of esters, such as testosterone enanthate, have been the mainstay of testosterone therapy. The introduction of testosterone patches has not challenged this approach, since many users of patches suffer from moderate to severe skin reactions. Some oral testosterone formulations have proven to be problematic, as absorption can be variable, bioavailability is frequently poor, due to the first-pass effect of the liver, and frequent administration is often required. Oral testosterone undecanoate avoids, at least partially, the first-pass effect of the liver. However, plasma testosterone levels generally undergo large fluctuations. The large fluctuations in serum testosterone levels caused by conventional intramuscular injections result in unsatisfactory shifts in mood and sexual function in some men, which, combined with the frequency of injections, make the intramuscular mode of delivery far from ideal. Recently, a hydroalcoholic gel containing 1% testosterone has proven to be as efficient as a testosterone patch, but with fewer side-effects and a higher grade of patient satisfaction. Doses of 50-100 mg gel applied once daily on the skin deliver sufficient amounts of testosterone to restore normal hormonal values and correct the signs and symptoms of hypogonadism. The gel has been shown to be effective and successful in patients in the United States, who have benefited from its availability for almost 3 years. In the near future, intramuscular injections of testosterone undecanoate will become commercially available. Such injections have a very favorable pharmacokinetic profile, with one injection every 3 months maintaining serum testosterone well within the normal range. In phase III studies, intramuscular testosterone undecanoate proved to be as efficient as testosterone enanthate, with only one-quarter of the number of injections required and more stable serum testosterone levels. Thus, the new application modes--hydroalcoholic gel (for example, Testogel, Schering AG, Germany) and intramuscular testosterone undecanoate (Nebido, Schering AG, Germany)--appear to be the methods of choice in the near future, one being very suitable for hormone therapy in elderly men, the other for long-term substitution in classical forms of hypogonadism.
    Source
    J Sex Med. 2005 Sep;2(5):716-21.
    Clomiphene citrate effects on testosterone/estrogen ratio in male hypogonadism.
    Shabsigh et all
    Abstract
    Symptomatic late-onset hypogonadism is associated not only with a decline in serum testosterone, but also with a rise in serum estradiol. These endocrine changes negatively affect libido, sexual function, mood, behavior, lean body mass, and bone density. Currently, the most common treatment is exogenous testosterone therapy. This treatment can be associated with skin irritation, gynecomastia, nipple tenderness, testicular atrophy, and decline in sperm counts. In this study we investigated the efficacy of clomiphene citrate in the treatment of hypogonadism with the objectives of raising endogenous serum testosterone (T) and improving the testosterone/estrogen (T/E) ratio.
    METHODS:
    Our cohort consisted of 36 Caucasian men with hypogonadism defined as serum testosterone level less than 300 ng/dL. Each patient was treated with a daily dose of 25 mg clomiphene citrate and followed prospectively. Analysis of baseline and follow-up serum levels of testosterone and estradiol levels were performed.
    RESULTS:
    The mean age was 39 years, and the mean pretreatment testosterone and estrogen levels were 247.6 +/- 39.8 ng/dL and 32.3 +/- 10.9, respectively. By the first follow-up visit (4-6 weeks), the mean testosterone level rose to 610.0 +/- 178.6 ng/dL (P < 0.00001). Moreover, the T/E ratio improved from 8.7 to 14.2 (P < 0.001). There were no side effects reported by the patients.
    CONCLUSIONS:
    Low dose clomiphene citrate is effective in elevating serum testosterone levels and improving the testosterone/estradiol ratio in men with hypogonadism. This therapy represents an alternative to testosterone therapy by stimulating the endogenous androgen production pathway.
      Source
      J Sex Med. 2010 Jan;7(1 Pt 1):269-76. doi: 10.1111/j.1743-6109.2009.01454.x. Epub 2009 Aug 17.
      Clomiphene citrate and testosterone gel replacement therapy for male hypogonadism: efficacy and treatment cost.
      Taylor et all
      Abstract
      INTRODUCTION:
      The efficacy of oral clomiphene citrate (CC) in the treatment of male hypogonadism and male infertility (MI) with low serum testosterone and normal gonadotropin levels has been reported.
      AIM:
      The aim of this article is to evaluate CC and testosterone gel replacement therapy (TGRT) with regard to biochemical and clinical efficacy and cost.
      MAIN OUTCOME MEASURES:
      The main outcome measures were change in serum testosterone with CC and TGRT therapy, and change in the androgen deficiency in aging male (ADAM) questionnaire scores with CC therapy.
      METHODS:
      Men receiving CC or TGRT with either Androgel 1% or Testim 1% for hypogonadism (defined as testosterone < 300 ng/mL) or MI were included. Serum values were collected 1-2 months after treatment initiation and semi-annually thereafter. Retrospective data collection was performed via chart review. Subjective follow up of patients receiving CC was performed via telephone interview using the ADAM questionnaire.
      RESULTS:
      A hundred and four men (65 CC and 39 TGRT) were identified who began CC (50 mg every other day) or TGRT (5 g). Average age (years) was 42(CC) vs. 57 (TGRT). Average follow up was 23 months (CC, range 8-40 months) vs. 46 months (TGRT, range 6-149 months). Average posttreatment testosterone was 573 ng/dL in the CC group and 553 ng/dL in the TGRT group (P value < 0.001). The monthly cost of Testim 1% (5 gm daily) is $270, Androgel 1% (5 gm daily) is $265, and CC (50 mg every other day) is $83. Among CC patients, the average pretreatment ADAM score was 4.9 vs. 2.1 at follow up (P < 0.05). Average pretreatment ADAM sexual function domain score was 0.76 vs. 0.23 at follow up (P < 0.05). There were no adverse events reported.
      CONCLUSION:
      CC represents a treatment option for men with hypogonadism, demonstrating biochemical and clinical efficacy with few side effects and lower cost as compared with TGRT
        Source
        Twenty-five milligrams of clomiphene citrate presents positive effect on treatment of male testosterone deficiency - a prospective study.
        Int Braz J Urol. 2012 Jul-Aug;38(4):512-8.
        Da Ros et all
        INTRODUCTION:
        Male testosterone deficiency is associated with bad sexual function and quality of life (QoL). The aim of this study was to determine whether a daily dose of 25 mg clomiphene citrate (CC) is effective in stimulating the endogenous testosterone production pathway and to address the applicability of this medication as a therapeutic option for symptomatic hypogonadism.
        MATERIALS AND METHODS:
        This was a prospective study. Men with low sexual desire and testosterone levels (T) below 400 ng/dL were selected to receive CC. Blood samples were obtained to determine baseline measurements of serum T, estradiol, LH, lipid profile and fasting plasma glucose. Each patient was treated with a daily dose of 25 mg CC for at least 3 months. Patients were asked if they experienced any side effects related to the use of CC and if they experienced any improvement in their sexual profile. Paired samples T-test was utilized to analyze responses to therapy.
        RESULTS:
        Our cohort consisted of 125 men with hypogonadism and low libido. Mean age was 62 years (± 11.1 years). Serum T levels ranged from 309 ng/dL (baseline, mean value) to 642 ng/dL (3 months after CC initiation, mean value) (p < 0.001). Serum cholesterol levels ranged from 197 to 186 mg/dL (p = 0.003). There were no statistically significant differences when comparing pre and post-treatment HDL-Cholesterol, triglycerides, fasting plasma glucose and prolactin. All men reported improvements in the post-treatment QoL scores. No serious adverse events were recorded.
        CONCLUSIONS:
        The CC was effective in stimulating the endogenous production of testosterone. A lower level of total cholesterol was verified after three months of treatment. This medication should be considered as a therapeutic option for some patients with symptomatic male testosterone
          a case study
          So I went to the doc to see if I can do a "restart" of my natural Testosterone after finding my T levels at a pathetic 350 ng/mL
          Here is the Protocol he gave me:
          -clomid: 15 mg every other day
          -Cabergoline: 0.5 mg weekly
          -Vitamin D: 5,000 IU daily
          -BPA Detox: Stop drinking/eating out of plastic containers
          -Super Sea Veg: (This is to help your body excrete BPA)
          -BONUS: Sublingual Testosterone Drops!: He gave me a small "eyedropper" bottle full of pure testosterone. (25mg per drop) He said anytime I need a "boost" I can put 3-5 drops under my tongue and get a surge of testosterone. Before the gym, before sex, before an important business presentation, etc.
          The Cabergoline is to lower Prolactin levels since I came in high.
          The Vitamin D is because my levels came in low in one of my previous blood tests. Raising Vitamin D will mean better T production.
          Below is my bloodwork when he had me on 25mg. of clomid per day to test my responsiveness:
          BLOODWORK RESULTS AFTER clomid test:
          -LH: 7.9 (1.7 - 8.6)
          -FSH: 4.6 (1.5 - 12.4)
          -Total Testosterone: 980 (348 - 1197)
          -Estradiol: 43.9 (7.6 - 42.6)
          -DHEA-Sulfate: 209 (160 - 449)
          -Prolactin: 19.6 (4.0 - 15.2)
          -igf-1: 227 (117 - 329)
          -SHBG: 49.7 (16.5 - 55.9) As you can see I responded well to the clomid which boosted my LH and FSH and shot my Testosterone through the roof.
          He told me that by taking clomid at a low dose of 15mg. every other day I can avoid the negative side effects.
          He also told me that if I find any negative side effects he can switch me over to HCG, but he'd rather try this first because clomid stimulates your natural LH production... Whereas HCG only mimics LH and you are bypassing part of your hypothalamus.
          Thought these results might be interesting to anyone who wants to try and restart their body's own T levels before you inject T and shut yourself down completely.
          I think anyone who is thinking about TRT should do this clomid test to see what your body is capable of... I had no idea I was able to boost my LH and T levels that high without injecting T... Pretty exciting stuff.
