Ok my first cycle went great now I'm going to add one more compound...deca. So it'll be 500 test 400 deca and tbol kick. So a couple questions I am prone to gyno so is adex enough (19-nor) I like what I read about proviron can it be ran. I've had some great input from one veteran but I wanna make sure I'm gtg guess I'm paranoid idk.....so any input is appreciated. Diet training weight etc.. all within reason pct not necessary (hrt).....or is it wow I'm confused
round two
Adex is great for test sides but 19-nor's can cause progesterone sides. These drugs cover progesterone/Prolactin sides:
Dostinex/Cabaser aka Cabergoline (.25mg ed) and should at least be on hand for any cycle with a 19-nor! Deca is one of my favorites and I've never ran into any problems running it but I'm always prepared if I do. Proviron like mast will block some estrogen just how much I'm not sure but it doesn't do anything for progesterone to my knowledge. Running it won't hurt anything but if you're trying to bulk you'd be better off with Dbol or the Tbol as an oral. If you're prone to gyno you may want to look into some letro. It's much stronger than adex (anastrozole) but you've got to find your sweet spot with it just like you do with adex. I would suggest you have some letro on hand with cycles as well if you're already gyno prone.
But here's the main thing to consider. Did you have good results with your first test cycle? If so then stick with that until you don't get good gains out of then add in another juice. You should get 2 or 3 good growth cycles out of test & oral kickstart cycles before you need to add deca. Keep it slow and easy this is a marathon and if you come out to strong you're going to burn out and need a ton of gear to grow in later cycles. Good luck.
Originally posted by manonmac1 View PostBut here's the main thing to consider. Did you have good results with your first test cycle? If so then stick with that until you don't get good gains out of then add in another juice. You should get 2 or 3 good growth cycles out of test & oral kickstart cycles before you need to add deca. Keep it slow and easy this is a marathon and if you come out to strong you're going to burn out and need a ton of gear to grow in later cycles. Good luck.
Dont get too greedy for gear, here are some pros or at least guys who have many cycles under their belt. Dont try to run their cycles yet.
Always make sure to do maximum gain with minimum gear. Dont overkill or you will loose that gain potential for later cycles.
GreetzLast edited by 123GetBigGER; 10-17-2013, 08:08 AM.
I would just stay at 500mg's! As for Tbol or dbol I like either at 50mg split doses(throughout the day)! With you being gyno prone just adding that little bit could cause you all kind of trouble! If you choose to up it just remember you may need to adjust your adex dose. But again on upping the dose I'm a if it ain't broke don't fix it till it is broke person!
GreetzThe Rules At Juiced Muscle (everyone please read)
Chat Box Talk And Rules
