okay so I have been using t3 for about 2 weeks. I only did 12.5mcgs the first week just to see how my body would react. My question is should I count that as part of my 6 weeks? I have read that my natty t3 won't even shut down with that dose. Then the second week which is ending now I did 25mcgs then 37.5mcgs just started 50mcgs. should i skip to 75mcgs? I also started clen at only 20mcgs to give it a shot. So what do you guys think?
T3 help
Listen guys that T3 is strong shit I hope your doing some Test with or your going to loose a lot more muscle than you plain on.The Rules At Juiced Muscle (everyone please read)
Chat Box Talk And Rules
i would say no to going up to 75mcg stay at 50mcg top and yes everyday you took it should count in your 6weeks even at low dose's you thyroid is not something to mess with and as Mrbig said are you running and test or gear to help keep muscle loss down? the t3 will cause muscle loss aswell as fat, you should be able to go up with the clen quite successfully but go up slowly untill you find whats good for you also you know to run the clen 2weeks on 2weeks off?, i guess this is your 1st time with both t3 and clen?Last edited by jimmy93; 03-25-2012, 05:31 PM.
This from a Bodybuilder
Clen/T3 Cutting Cycle...
This is a 6 week cycle :
Clen is taken 1 week on / one week off:
As in my experience it is more effective this way:
A mild anabolic of 50mg of Winstrol ED, Anavar at
40mg ED or Test Prop at 50mg ED or 100mg EOD is
recommended to preserve muscle lose and fight of
a catabolic state that T3 can cause. You could also
use longer ester testosterone , but they will take much
longer to kick in to be effective.
Start T3 at 50mcg as any lower makes no sense since
your body should be producing between 20mcg-25mcg
daily naturally... Clen doses use as a guideline along with
the T3 doses, everyone has different tolerances for both,
but this is was very effective for me...
You can use a simple ECA stack during your off weeks in the
place of Clen if you want to help with the fat burning progress...
Your diet should be fairly high in protein , moderate carbs with
no sugars and moderate fat intake... You may also want to add
a source of EFA's like a flax seen oil to your diet during this time...
Also Clen is known to cause alot of muscle cramping... Also I start
off week three at the same dose I finished with at the end of week
one... Again all depends on your tolerance to the drug, you may
want to start a little lower for a few days before going right back
to your maximum dose.
Drink more water along with taking extra minerals and potassium
and 2-3 grams ED of the amino acid L-Taurine is recommended if
cramping is really a problem... Also take your Clen and T3 in two
divided doses during the day... Also to give you an idea my daily
calorie intake was probably about 1,000 to 1,200 lower then normal
for this entire time...
BTW when I ran this cycle I was running 900mg week of Test Cyp
as my only anabolic right at the end of a bulking cycle ... My results
is I went from a chunky, but thick as a bull 240lbs to a fairly hard 212lbs
or so in only 6 weeks... Again adjust the doses to fit your tolerance...
At these doses you will be sweating and hot all day long... Plan on
losing some muscle mass even with the anabolics...
Day 1 Clen 60mcg / T3 50mcg
Day 2 Clen 60mcg / T3 50mcg
Day 3 Clen 80mcg / T3 75mcg
Day 4 Clen 100mcg / T3 75mcg
Day 5 Clen 100mcg / T3 75mcg
Day 6 Clen 120mcg / T3 100mcg
Day 7 Clen 120mcg / T3 100mcg
Day 8 Clen off / T3 125mcg
Day 9 Clen off / T3 125mcg
Day10 Clen off / T3 125mcg
Day11 Clen off / T3 125mcg
Day12 Clen off / T3 125mcg
Day13 Clen off / T3 125mcg
Day14 Clen off / T3 125mcg
Day15 Clen 120mcg / T3 125mcg
Day16 Clen 120mcg / T3 125mcg
Day17 Clen 120mcg / T3 125mcg
Day18 Clen 120mcg / T3 125mcg
Day19 Clen 120mcg / T3 125mcg
Day20 Clen 120mcg / T3 125mcg
Day21 Clen 120mcg / T3 125mcg
Day22 Clen off / T3 125mcg
Day23 Clen off / T3 125mcg
Day24 Clen off / T3 125mcg
Day25 Clen off / T3 125mcg
Day26 Clen off / T3 125mcg
Day27 Clen off / T3 125mcg
Day28 Clen off / T3 100mcg
Day29 Clen 120mcg / T3 100mcg
Day30 Clen 120mcg / T3 100mcg
Day31 Clen 120mcg / T3 75mcg
Day32 Clen 120mcg / T3 75mcg
Day33 Clen 120mcg / T3 75mcg
Day34 Clen 120mcg / T3 50mcg
Day35 Clen 120mcg / T3 50mcg
Day36 Clen off / T3 50mcg
Day37 Clen off / T3 50mcg
Day38 Clen off / T3 25mcg
Day39 Clen off / T3 25mcg
Day40 Clen off / T3 25mcg
Day41 Clen off / T3 25mcg
Day42 Clen off / T3 25mcg
