Hello. I have been told to start out with TEST, in a low dose. Any suggestions.
New to Steroids??? Help
I know!
Therefor you should read some about testo.
Basic is:
You use it on a regular dose in a regular timeline.
At the same time you use a medicine that blocks the sides from testo.
After your are done with the use of testo you need to use a medicine to start up your own testo in your body because it will stop when you use testo.
Originally posted by Bonzo View PostSounds ok!
But you should spend some time in the forum and read about sides ...
If you start to use TEST you will end up with gyn (man boobs).
Did you really just say that if he used test he will end up with man boobs??Last edited by F.I.S.T.; 05-31-2011, 11:46 PM.
iam about to do my second cycle, tren enathate, deca 300, masteron 200, primobolan, winnie tabs 50mgs, test cyp, dont know if its overkill but will be doing a 16 week cycle. my quess to this cycle is it should rip me right up except for the tren and test but with a strict diet and cardio plan should get great results. i never used geneza before so dont know if quality is on point but will see. what do you fellas think about geneza and this stack?
