I have two big jugs of cell-tech and was wounding if it's ok to take on gear
Creatine is it ok to take with gear?
It's fine to take creatine when on cycle but the reason many use it when off cycle (during pct onwards) is you wont see so much loss in your gains. When coming off cycle there are pshycological factors to look at. You're loosing the chemicals you had inside you and you're gonna feel a little different mental, possibility of mild depression and also the loss of a little size, strength and shape which can add to depression. Taking creatine after your cycle will help keep a similar size, shape & weight and can therefore help counter some depression as you'll still see yourself at a good size even when you've finished your PCT. It's a mix of mental and physical reasons for me why I and many use it off cycle. Using it on cycle is just overkill IMO.
Originally posted by Cage fighter View PostWhat a good lower chest workout if you can't do declines ?
http://www.youtube.com/watch?v=5Ytn_...eature=related
the only time im reluctant to use creatine on a cycle is when im on something like tren, because the two of them together will seriously dehydrate you. i was drinking plenty of water and was still cramping during my workouts. everybodys different though, what effects me might not be the same for you
