Hey, New female member here.
  • Hey, New female member here.
    Hey all i'm Tabby. I use to be quite obese but lost over 150lbs! as can be seen in the phtos below i've got a lot more new photos since then. the only operation I've had is "Breast enlargment" I was able to sort out any loose skin problems. I now do erotic modeling for a living lol.
    I look forward to meeting you all and reaching our goals together!
    Currently I feel my lower body is fantastic but the upper body needs some work.
    few more pics
      last set. Weights at the moment are squat 155kg, for 12 reps.
      Deadlift I did 3 sets of 8 at 120kg yesterday
      Bench press 85kg
      Overhead press 50kg
        Thats not a chick...
        Building my self for a better tomorrow.
          No the two lumps on my chest clearly indicate i'm a male. Unless you don't believe the account is female? which it is lol. A lot of girls use anavar/npp when bulking or cutting.
            Guys cant smile like that im convinced.
            Rest is first class to keep it up u have obviously worked very hard and can be proud.
              Bahahahahah
              Go Hard Or Stay Home!!
                Well good for you, that's a heck of a lot of weight to lose, no easy task.
                  Welcome to JM You look feminine enough to me.
                  And even if a transgender would want to join, why not?
                  I would like it if you would post your experiences on that amount of fat loss and how you managed the excess skin.
                    Welcome to the boards. Noticed the physique but also the absence of a ring on that left hand. Nice build.
                      Feminine enough for you?
                        Loose skin wise, What I did and have had to do was make sure I did Weights, Alot of my cardio was involved around "Weight lifting" So I had to build mass.
                        To start with for example I did a routine Charles poliquin wrote.
                        Basically if you were training chest you'd do Bench press 10 reps. 10 second break. Then you'd drop it to a weight you could do for 15 reps, 10 second break, then eventually 25 reps.
                        You'd then have a 2 minute break before repeating 3 more times. Then you'd go onto the next muscle group which was back.
                        On leg day it'd be the same etc.
                        That was 4 days per week with HIIT for cardio another 2 days.
                        Especially due to me being new to weights I was able to add mass while quickly dropping fat.
                        The only surgery i've required is my breasts. I never got Saggy boobs, But I went from a decent sized to a B cup, and I wanted larger.
                          Yes, you are, very nice..
                            thanks! Didn't see this till now lol.
