Test E 200mg / EQ 200mg
  • Test E 200mg / EQ 200mg
    Has anyone tried this blend from GP? If so, how does it stack up compared to dosing each one individually? And in anyone's opinion which is a better setup? Haven't seen many reviews on the blends.
    Thanks in advance
    1 More_Rep
    Member
    <a href="http://napsgear.org/?ref=218" target="_blank"> <img src="http://napsgear.org/customers_boards_banner_218.gif"/> </a>
    Well, has anyone tried any of the blends? If so, what do you think?
      I tried the andromix. But had to add alittle more to it.
        So basically it's best to buy them individually rather than to buy the mix?
          I haven't personally used any of them but i was going to run the test/EQ blend at 200mg e4d and add prop throughout at 100mg eod to keep my test levels higher than the EQ. Just an option
          I think the test/deca and test/tren e blends would be good as is no matter how many cc you go with. I do wish the andromix was 100 mg of each compound or at least 100mg of test p. it would make it a little more attractive to me
          "I COUNT HIM BRAVER WHO OVERCOMES HIS OWN DESIRE THAN WHO CONQUERS HIS ENEMIES, FOR THE HARDEST VICTORY IS OVER SELF"
          "SUCCESS ISN'T ALWAYS ABOUT GREATNESS. IT'S ABOUT CONSISTENCY. CONSISTENT HARD WORK GAINS SUCCESS. GREATNESS WILL COME"
            Ill say what I always say to questions like this, I Hate Blends!! I would rather buy them all seperate
              JD I think I'm starting to feel the same way, buy them all separate and call it a day. At least you'll know exactly how much gear you're injecting.
                i'm using it. it kicks ass. less oil to get a high mg. if you want to alter the dosing, say it you wanted to take more test, you can always pic up an additional vial or two of test e.
                if you're familiar with the GP line, the oil is thin and watery, like the rest of their products. i'm using a 25g pin, no problems. its been pretty much painless. let me know if you have any specific questions
                  whys that bro?
                  sam1976
                    Appreciate the input Sam, what kind of gains are you getting off this particular blend (Test E 200mg / EQ 200mg) ? Have you ran them separate before? If so, how do they compare result wise?
                    Thanks in advance
                      Thanks in advance
                      i have run it before. its exactly the same as when separate, as far as i can tell. this time around, i actually started running a different brand which was not in a blend. after 8 wks, i swapped to the blend. if anything, i like this better than the previous brand. i like the way that gp gear is super thin and easy to put in the muscle. i am super hungry off of it. along with the other gear i'm using, i'm at my all time biggest....also have been runing gp injectable dbol. just swapped that out for GP NPP
                        especially with something like EQ where you're using more cc's of oil, blends are nice. less oil to have to find a place for
                          Appreciate the input Sam, I just might give the blend a try. As you said, less oil to have to find a place for.
                            how much are you planning on using? remind me, whats your cycle experience??
