Mixing GP Test Cyp with Watson Test Cyp...
  • Mixing GP Test Cyp with Watson Test Cyp...
    I wouldn't think this a problem..
    But I know they use different oils... Watson has a slight brown colour and tastes like it might be cottonseed.
    GP is clear, maybe grapeseed or linseed oil. Is it cool to mix the two 1/2mls into 1 ml?
    I have to do this today... mixing 1/2 ml of my trt Watson cyp with 1/2 ml GP cyp...
    After first draw, pull back another 1/2 ml of air into the barrel and inject that amount of air into the second vile, making sure to leave a small amount of air so not to mix...that way I can easily draw the second oil in, flick the syringe to get bubbles to tip...put on the inj needle, push the air out...
    Am I gtg?
    You are gtg, unless you are alergic to certain type of oil, then you need to be careful.
      Nah, I've already been exposed to both...no worries. I just don't want to pin so much.
      Thnx powerhouse! ... I appreciate the quick reply.
        Not a problem at all
