Drug blood test
  • Drug blood test
    Can you tell me what a normal blood test (here) can prove? Does such a blood test can show that I tried anabolics once a few weeks ago?
    orangen
    so steroids are "evil" lol ? for your average run of mill job, you will be fine. here is a post by mfreaky over at OLM
    The 5 panel /10panel drug test is a qualitative immunoassay for detecting all of these drugs from a single urine sample. If your concern about your Job testing for AAS is not part of 5/10 panels program. The Criminal justice field Ex, LE,FBI,CIA etc will be tested for AAS. Hair Sample Test has becoming more common in the pre-emplyoment screening process.
    The Five Panel Drug Test is commonly used among as part of pre employment process.
    The Ten Panel Drug Test is commonly used for Doctor, Medicine field, LE or . It may be used to determine if an employee was under the influence of drugs at the time of a workplace accident or injury. Law enforcement officials may use this test to monitor offenders who are on probation or enrolled in work release programs. If a positive test result occurs, an offender may be put in jail on a probation violation.
    11 Panel Steroid Test most of employer do not participate Drug Testing for Steroid (AAS) Most likely Criminal justice field Ex, LE,FBI,CIA etc will be tested for AAS.
    Anabolic Steroid Agents and metabolites Tested
    - Testosterone
    - Noretiochola
    - Oxymetholone
    - Dehydroepiandrosterone
    - Nortestosterone
    - Hydroxyandrosterone
    - Methandienone
    - Norandrosterone
    - Hydroxyetiocholanolone
    - Epitestosterone
    - Stanozolol (Winstrol)
    5 Panel Test includes of variety deferent 5 Panel depending on your Employer Request.
    Cocaine, Amphetamines, Methamphetamines, Marijuana & Opiates
    Cocaine, Methamphetamines, Marijuana, Opiates & Phencyclidine
    Cocaine, Amphetamines, Marijuana, Opiates & Phencyclidine (also known as the NIDA 5 Drug Test)
    Cocaine, Methamphetamines, Marijuana, Morphine (opiates 300) & Benzodiazepines
    Cocaine, Amphetamines, Benzodiazepines, Marijuana & Opiates
    Cocaine, Methamphetamines, Marijuana, Ecstasy & Opiates
    10 Panel Test includes
    Cocaine (COC),
    Amphetamine (AMP),
    Methamphetamine (mAMP),
    Marijuana (THC),
    Methadone (MTD),
    Opiates (OPI),
    Phencyclidine (PCP),
    Barbiturates (BAR),
    Benzodiazepines (BZO)
    Tricyclic Anti-depressants (TCA).
    Methamphetamine Urine Testing
    Methamphetamines are one of the "NIDA 5" - the five drugs tested for in the standard NIDA approved drug test. Methamphetamines are first detectable in urine 1-3 days after use, however the drug stays in the system aproximately 3-6 days.
    Methamphetamine test is a one step competitive immunoassay that is used to screen for the presence of methamphetamines in urine. It is a chromatographic absorbent device in which drug or drug metabolites in a sample compete with drug conjugate immobilized on a porous membrane for a limited number of binding sites. This test is a rapid, qualitative immunoassay for the detection of amphetamine in urine. The cutoff concentration for this test is 1000 ng/ml, as recommended by the Substance Abuse and Mental Health Services Administration (SAMHA) and NIDA." The cutoff for GC-MS, which detects d-amphetamine and methamphetamine, is 500 ng/ml.
    Opiates Urine Testing
    Opiates are one of the "NIDA 5" - the five drugs tested for in the standard NIDA approved drug test. The standard tests are a one step rapid qualitative immunoassay for the detection of opiate and opiate metabolites in urine. The cutoff concentration for this test is 2000 ng/ml, as recommended by the Substance Abuse and Mental Health Services Administration (SAMHSA) and the U.S. National Institute of Drug Abuse (NIDA). Prior to December 1, 1998 the cutoff level was 300 ng/ml but was raised in order to reduce the possibility of false positives from poppy seeds. The cutoff for GC-MS, which detects morphine or codeine, is 150 ng/ml. The US Military uses a cutoff level of 3000 ng/ml in order to try to avoid false positives.
    Amphetamine Urine Testing
    Amphetamines are one of the "NIDA 5" - the five drugs tested for in the standard NIDA approved drug test. Amphetamines are detectable in urine for 1-3 days after use. Methamphetamines stay in the system slightly longer, usually 3-5 days.
    The Amphetamine test is a one step competitive immunoassay that is used to screen for the presence of amphetamine in urine. It is a chromatographic absorbent device in which drug or drug metabolites in a sample compete with drug conjugate immobilized on a porous membrane for a limited number of binding sites. This test is a rapid, qualitative immunoassay for the detection of amphetamine in urine. The cutoff concentration for this test is 1000 ng/ml, as recommended by the Substance Abuse and Mental Health Services Administration and NIDA." The cutoff for GC-MS, which detects d-amphetamine and methamphetamine, is 500 ng/ml.
    Marijuana Urine Testing
    THC (marijuana / cannabis) is one of the "NIDA 5" - the five drugs tested for in the standard NIDA approved drug test. THC is detectable in Urine for 48-72 hours after single use. Habitual or chronic use can be detected in urine for up to 12 weeks depending on quantity, duration, and frequency of use.
    Tetrahydrocannabinol is rapidly absorbed by inhalation and the gastrointestinal tract. It is almost completely metabolized. The predominant metabolite is 9-carboxy-11-nor-delta-9-THC, which found in the plasma, feces, and urine along with other compounds. Very low concentrations of THC may be detected in urine during the initial several hours, but tetrahydrocannabinol persists in urine at a detectable concentration for many days after smoking.
    The standard THC test is a one step rapid, qualitative immunoassay for the detection of tetrahydrocannabinol compounds (11-nor-THC-9-Carboxylic Acid) in urine. The cutoff concentration for a positive result in an immunoassay test is 50 ng/ml as recommended by the Substance Abuse and Mental Health Services Administration (SAMHSA) and NIDA. The cutoff for GC-MS is 15 ng/ml.
    Cocaine Urine Testing
    Cocaine is one of the 'NIDA-5" "NIDA 5" - the five drugs tested for in the standard NIDA approved drug test. It can be detected approximately 48-72 hours after single use. Frequent or heavy use can be detected for longer periods.
    The initial screening cutoff level is 300 ng/ml for cocaine and its metabolite benzoylecgonine. The GC/MS cutoff level is 150 ng/ml
      Oh how I dont miss the stress of a drug test...nice post Sam...oh, and how do you "try" anabolics ?
      ZOOT
        Sorry, I normally don't use sarcasm here but I am just imagining dude half drunk, downing a handful of dbol and getting into a bench press contest with his buds. Only to wake up the next morning realizing that he committed an "evil" and he had a drug test comin' up. Then scrambling to find info on the internet. LOL "one time evil" LOL
