Calculating Calories and Macro's
  • Calculating Calories and Macro's
    Basic Terminology
    1/ BMR (Basal Metabolic Rate): This is the amount of calories you need to consume to maintain your body if you were comatose (base level).
    2/ NEAT (Non-Exercise Associated Thermogenesis): The calorie of daily activity that is NOT exercise (eg: washing, walking, talking, shopping, working). ie: INCIDENTAL EXERCISE! It is something that everyone has a good amount of control over & it is the MOST important factor in your energy expenditure. It is what helps keep 'constitutionally lean' people LEAN (they fidget)!
    3/ EAT (Exercise Associated Thermogenesis): The calorie requirements associated with planned exercise. Unless someone is doing a whole heap of exercise (eg: two or more hrs training a day) it usually doesn't add a stack of calories to your requirements (30 minutes of 'elliptical training isn't going to do it')
    4/ TEF (Thermic effect of feeding): The calorie expenditure associated with eating. REGARDLESS of what myths you have been told - this is NOT dependent on MEAL FREQUENCY. It is a % of TOTAL CALORIES CONSUMED (and 15% of 3 x 600 cal meals is the same as 15% of 6 x 300 cal meals). It varies according to MACRONUTRIENT content and FIBER content. For most mixed diets, it is something around 15%. Protein is higher (up to 25%), carbs are variable (between 5-25%), and fats are low (usually less than 5%). So -> More protein and more carbs and more fiber = HIGHER TEF. More FAT = LOWER TEF.
    5/ TEE (Total Energy Expenditure): The total calories you require - and the sum of the above (BMR + NEAT + EAT + TEF).
    How much do you need?
    There is therefore a multitude of things that impact a persons MAINTENANCE calorie requirements
    - Age & sex (males generally need > females for any given age)
    - Total weight & lean mass (more lean mass = more needed)
    - Physiological status (eg: sick or injured, pregnant, growth and 'enhancement')
    - Hormones (eg: thyroid hormone levels, growth hormone levels)
    - Exercise level (more activity = more needed)
    - Daily activity level (more activity = more needed)
    - Diet (that is - macronutrient intake)
    In order to calculate your requirements the most accurate measure is via Calorimetry [the measure of 'chemical reactions' in your body & the heat produced by these reactions], either directly (via placing a calorimeter where the heat you produce is measured) or indirectly (eg: HOOD studies where they monitor how much oxygen you use/ carbon dioxide and nitrogen you excrete over a given time). But although accurate they are completely impractical for most people & we mostly rely on pre-set formula t0 calculate our needs.
    Estimating Requirements
    The simplest method of estimating needs is to base your intake on a standard 'calories per unit of weight (usually kilograms)'. Typically:
    - 26 to 30 kcals/kg/day for normal, healthy individuals with sedentary lifestyles doing little physical activity [12.0-14 kcal/pound]
    - 31 to 37 kcal/kg/day for those involved in light to moderate activity 3-5 x a week with moderately active lifestyles [14-16 kcal/ pound]
    - 38 to 40 kcals/kg/day for those involved in vigorous activity and highly active jobs [16-18 kcal/ pound].
    For those involved in HEAVY training (eg: athletes) - the demand is even greater:
    - 41 to 50 kcals/kg/day for those involved in moderate to heavy training (for example: 15-20 hrs/ week training) [18.5-22 kcal/ pound]
    - 50 or above kcals/kg/day for those involved in heavy to extreme training [> 22 kcal/ pound]
    There are then a number of other formula which calculate BMR.
    1/ Harris-Benedict formula: Very inaccurate. It was derived from studies on LEAN, YOUNG, ACTIVE males MANY YEARS AGO (1919). Notorious for OVERESTIMATING requirements, especially in the overweight. IF YOU CAN AVOID IT, DON'T USE IT!
    MEN: BMR = 66 + [13.7 x weight (kg)] + [5 x height (cm)] - [6.76 x age (years)]
    WOMEN: BMR = 655 + [9.6 x weight (kg)] + [1.8 x height (cm)] - [4.7 x age (years)]
    2/Mifflin-St Jeor: Developed in the 1990s and more realistic in todays settings. It still doesn't take into consideration the differences as a consequence of high BF%. Thus, once again, it OVERESTIMATES NEEDS, ESPECIALLY IN THE OVERWEIGHT.
    MEN: BMR = [9.99 x weight (kg)] + [6.25 x height (cm)] - [4.92 x age (years)] + 5
    WOMEN: BMR = [9.99 x weight (kg)] + [6.25 x height (cm)] - [4.92 x age (years)] -161
    3/Katch-McArdle:Considered the most accurate formula for those who are relatively lean. Use ONLY if you have a good estimate of your bodyfat %.
    BMR = 370 + (21.6 x LBM)Where LBM = [total weight (kg) x (100 - bodyfat %)]/100
    You then multiply these by an 'activity variable' to give TEE. This Activity Factor[/u] is the cost of living and it is BASED ON MORE THAN JUST YOUR TRAINING. It also includes work/lifestyle, sport & a TEF of ~15% (an average mixed diet). Average activity variables are:
    1.2 = Sedentary (Little or no exercise + desk job)
    1.3-1.4 = Lightly Active (Little daily activity & light exercise 1-3 days a week)
    1.5-1.6 = Moderately Active (Moderately active daily life & Moderate exercise 3-5 days a week)
    1.7-1.8 = Very Active (Physically demanding lifestyle & Hard exercise or sports 6-7 days a week)
    1.9-2.0 = Extremely Active (Hard daily exercise or sports and physical job)
    So to convert BMR to a TOTAL requirement: multiply the result of your BMR by the variable you fall into!
    How Accurate are they?: Well, although they give rough ball-park figures, they are still 'guesstimations' and most people still OVERESTIMATE activity, UNDERESTIMATE bodyfat & end up eating TOO MUCH. So the aim is to use these as 'rough figures', monitor your weight/ measurements for 2-4 weeks, & IF your weight is stable/ measurements are stable, you have likely found maintenance.
    Using the Above to Recalculate Based on Goals
    You then need to DECREASE or INCREASE intake based on your goals (eg: lose or gain mass). And instead of using 'generic calorie amounts' (eg: 500 cals/ day), this should be calculated on a % of your maintenance. Why? The effect of a given calorie amount on an individual is going to be markedly different based on their size/ total calorie intake. For example - subtracting 500 cals/ day from a 1500 total intake is 1/3rd of the total cals, where 500 cals/ day from 3000 total intake is only 1/6th of the total. The results will therefore be markedly different on an individuals energy level & weight loss. So generally:
    - To ADD weight: ADD 10-20% calories to the total above
    - To LOSE weight: SUBTRACT 10-20% calories from the total above
    Then monitor your results and adjust as required.
    NOTE: IF YOU ARE LESS THAN 18 YRS OF AGE - THESE FORMULA WILL NOT BE ACCURATE!There is an energy cost associated with growth / inefficient movement / high surface area:mass ratio. Look HERE for alternatives.
    As a teenager I would also STRONGLY suggest you don't obsess on calories and macros! Eat well, exercise regularly, and have fun while you can!
    Macronutrient NeedsOnce you work out calorie needs, you then work out how much of each macronutrient you should aim for. This is one of the areas that is MOST often confused but This should NOT be based on a RATIO of macro intakes. (eg: '30:40:30 or 40:40:20') Your body doesn't CARE what % intake you have. It works based on SUFFICIENT QUANTITY per LEAN MASS or TOTAL MASS. So to try to make it as simple as possible:
    1. Protein: Believe it or not - Protein intake is a bit of a controversial issue. In this, the general recommendations given in the 'bodybuilding' area are nearly double the 'standard' recommendations given in the Sports Nutrition Arena.
    The GENERAL sports nutrition guideline based on most studies out suggest that in the face of ADEQUATE calories and CARBS then the following protein intakes are sufficient:
    STRENGTH training -> 1.2 to 1.6g per KG bodyweight (about .6 / pound)
    ENDURANCE training -> 1.4 to 1.8g per KG bodyweight (about .8 / pound)
    ADOLESCENT in training -> 1.8 to 2.2g per KG bodyweight (about 1g / pound)
    BUT they also acknowledge that protein becomes MORE important in the context of LOWER calorie intakes, or LOWER carb intakes.
    Regardless of this, the general 'bodybuilding' guidelines would be as follows:
    - If you guess your bodyfat is AVERAGE = 1-1.25g per pound TOTAL weight
    - If you KNOW your bodyfat = 1-1.5g per pound LEAN weight
    If you are VERY LEAN or on a VERY LOW CALORIE INTAKE then protein should be higher:
    - Average bodyfat, lower calorie intake = 1.25-1.5 per pound total mass
    - Very lean, lower calorie intake = 1.33-2 per pounds lean mass
    If you are VERY OVERWEIGHT, VERY INACTIVE, or on a HIGH calorie diet then you can decrease BELOW the above levels if desired*= ~ 1 x LEAN mass to 0.8-1 x total weight in pounds
    Anecdotally, most find the HIGHER protein intake better for satiety, partitioning, and blood sugar control. So UNLESS you are specifically guided to use the GENERAL sports nutrition guidelines, I would suggest the BODYBUILDING values.
    2. Fats: Generally speaking, although the body can get away with short periods of very low fat, in the long run your body NEEDS fat to maintain general health, satiety, and sanity. Additionally - any form of high intensity training will benefit from a 'fat buffer' in your diet - which acts to control free radical damage and inflammation. General guides:
    Average or lean: 1 - 2g fat/ kg body weight [between 0.45 - 1g total weight/ pounds]
    High bodyfat: 1-2g fat/ LEAN weight [between 0.45 - 1g LEAN weight/ pounds]
    IF low calorie dieting - you can decrease further, but as a minimum, I would not suggest LESS than about 0.35g/ pound.
    Note 1: Total fat intake is NOT the same as 'essential fats' (essential fats are specific TYPES of fats that are INCLUDED in your total fat intake)...
    3. Carbs: Important for athletes, HIGHLY ACTIVE individuals, or those trying to GAIN MASS, carbs help with workout intensity, health, & satiety (+ sanity).
    For carbs there are no specific 'requirements' for your body so for 'general folk' to calculate your carbs you just calculate it from the calories left over from fats/ protein:
    carb calories = Total calorie needs - ([protein grams as above x 4] + [fat grams as above x 9])
    carbs in grams = above total/ 4
    If you are an athlete - I would actually suggest you CALCULATE a requirement for carbs as a PRIORITY - then go back and calculate protein / fat:
    moderately active: 4.5 - 6.5 g/ kg (about 2 - 3g/ pound)
    highly active: 6.5 - 9 g/ kg (about 3 - 4g/ pound)
      Question on this part:
      Is this party saying for example the "Average or lean: 1 -2g fat/ kg body weight" Is this saying 1-2g fat PER kg of body weight or 1-2g kg DIVIDED by kg of body weight? Anyone know?
