Anavar & Agmatine
  • Anavar & Agmatine
    Gearing up to run a solo 6 week cycle of Anavar had originally planned to run it with d-bol and test but at this point I'm on the verge of signing a modeling contract and can't get any bigger. My question is I've heard that it's good to run creatine while on cycle and was wondering if running Agmatine (basically a new supposedly better form of N.O.) would be beneficial. I've heard running an N.O. booster on cycle could result in elevated blood pressure, although I was wondering with Var being such a mild compound if it would interfere with my blood pressure.
    Thanks in advance
    <a href="http://napsgear.org/?ref=218" target="_blank"> <img src="http://napsgear.org/customers_boards_banner_218.gif"/> </a>
    Any input?
      I've also wondered about supplementing creatine w/anavar.
        1 more rep, PM about the modeling i'm interested as I am also in similar position. As for anavar, it is the mildest oral compound. It helps more so with strength than actual physical gains. It only helps when ur bf is already under 8%, to achieve even more of a lean look. As for creatine, it will just bloat you with water which isn't the best for photos but i just use it after a cycle. I find that it helps me maintain my gains a little better. As for agmatine, great for pumps and keeping steady blood flow through out the day. Pm me so we can talk more.
