Looking on Naps
  • Looking on Naps
    I'm looking on Naps and I came across Sachets. Six options there but my question is this....
    What is a Sachet?
    its a soft pouch instead of a glass vial
      is it still liquid? or powder that needs reconstituting?
        its oil and ready to be used
          Oil in a soft pouch? I'm so lost. The site reads 5ml sachet...
            Anabolic Steroids packed in Sachets, also known as stealth injectables. Steroids packed in such way are unique in many views as they are considered to be the future of mail order steroids, meaning they are undetectable by border customs. The paper of the sachet is made of few different layers which protects the contents from outer elements and it meets the highest medical standards. Such packing, as long as it is factory sealed, is as good and strong as a glass vial.
            Each sachet is designed to pass any inspection without raising a suspicion. It doesn't contain any obvious markings which would imply on the contents - a casual observer would think that the sachet contains some kind of massage oil. A sachet size is approximately 2 by 2 inches and not more than 1/4" thick. When shipped by mail it is no more suspicious than a simple postcard.
            However, each sachet contains the small and simple imprinted markings on the back side which identify the contents together with a date of production in eight digits followed by 2 or 3 letter code that identifies the product. For example BU represents Boldenone Undecylenate. So the imprinted code would be 13.05.2006.BU.
            How to use sachets:
            The easiest way to take the steroid out is the same as taking it out from a vial:
            1. Before drawing the steroid out of the sachet, it's recommended to warm it up somewhat as the oil is less dense when warm - You can do that simply by placing it over a hot cup of water and the steam will heat it up in half a minute. Don't actually put it in water as you might heat it up too much.
            2. Prepare your needle/syringe, then pierce the corner of the sachet. Only pierce a quarter of an inch deep, and make sure you do that at a right angle so the needle won't get out on the other side.
            3. Start drawing the plunger immediately or the oil could drip out at the sides.
            4. You need to drain the sachet completely - you can't keep the steroid substance inside once you've opened it.
            5. If you won't use the whole 3 ml in one shot, you should drain the sachet completely and then inject the liquid into a multi-dose vial and store it for later use. If you don't have a vial at hand, you can also store it in the syringe for few days. (replace the needle immediately after use and put a fresh needle on. Keep the syringe in a dry and dark place at room temperature).
              WOW thanks a ton... that helped a lot.
                hey thats interesting.. cut back on re-ships.. time and money..
                Body please don't hurt the gym for it knows not what it does to you..
                  wow that is really interesting, bump for meatheads thinking ahead of the game. well played
