Cutting cycle anavar tren test
  • Cutting cycle anavar tren test
    Whats up guys
    Got some questions hopefully i get some good advice.
    Im starting my new cycle and this is what it looks like
    1-12 tren
    1-12 test
    1-6 anavar
    And i was told to do masteron 7-12
    What do you guys think?
    Any doses suggestions?
    How many cycles have you done, Tren can be VERY harsh?
      Its my 4th cycle
      Ive ranned tren with every cycle so im
      Not worried about it
      Im more worried about masteron and if it will have any side effects
      Sent from my iPhone using Tapatalk
        Do you want to build or cut?
        Sent from my SM-T377V using Tapatalk
          Im trying to cut.. what do you think?
            Have you looked into a Winstrol/test stack?
              That is a lot of pinning if you do tren Ace daily. 84 times just for the tren alone.
              I just finished a tren e test cyp cycle and I gained a couple lbs of muscle and lost 4 or so of fat, but I couldn't lift much and didn't eat right. I also took accutane for 80 days and it kicked my ass serious. The tren was harsh but not too bad. 12 weeks of tren e would be as long as I would ever do I think I did 10 and it was rough as fuck. I just started test e and drol and I feel better than I did the whole time on tren e. I prefer Ace but ed pinning sucks.
              But I did get shredded because I work outside and it's been hot as fuck.
                Guys, there's no reason to pin a fast easter ed, eod is good. It will keep your blood level steady enough.
                  Sounds ok. What about PCT?
                    Test, Tren, and Anavar is plenty IMO. You don't need the Mast. bro. I've done countless different compounds together over the years and I've found nothing beats a good Test base and Tren. That is, if the Tren doesn't bother you. You run those with a solid diet and you should see results. I think often people miss the mark due to their diet. That goes for bulking or cutting. You get that right with a sufficient amount of AAS and you're set.
                    Best of luck to you.
                      Do you think it suppresses hunger? I plan to use it but don't want to affect my nutrition.
