Hey JM,
Looking for some answers. I've spent a lot of time the last two weeks regarding front loading procedures.
I feel comfortable regarding my plan for the upcoming test e and tbol cycle. Then the use of steroid calculator I've selected levels that I am comfortable with to maintain blood levels throughout the duration of the cycle.
However where many websites or articles fall short is the mention of AIs when front loading. Or if it's even necessary if one has not had issues in the past.
My question is the following.
I'm only running 500mg a week. Broken into 2 x 250mg
10 week cycle.
Front load 750mg
Pin twice weekly 250mg Sunday / Thursday.
Last week run a short 50mg a day tbol run to keep things moving into pct.
Now. I did not have any issues with Gyno etc the first run. However I did have a big issue with estrogen rebound. I have aromasin now included into my pct to combat those issues.
If I did not have issues before, do I need to run an AI as a precaution or is it a better idea to see how my body reacts?
On hand I have letro, aromasin, clomid and nolvadex. However most of the above are set aside for pct. Yet that doesn't mean I can't put this cycle off a few weeks if need be to get more of what is needed.
Thanks for your time. Hopefully this thread will get some informed responses from the experienced users on JM. My guess is others have had the same questions at one time or another.
Cheers.
Results 1 to 6 of 6
Thread: Ancillaries and Front Loading
11-13-2016 10:59 PM #1
09-03-2018 02:41 PM #2
Great one!
12-09-2018 04:01 AM #3
You have way more than what you need for pct. So if a problem arises just hit the letro or AROMASIN for a quick knockdown
Sent from my SM-G960U using Tapatalk
02-03-2019 05:49 PM #4
02-03-2019 06:00 PM #5
I use aromasin every 3rd day 12.5mg. For pct I just use novladex and clomid. This cycle was 600 testE 600EQ 600deca 50dbol/anavar daily weeks 1-6. Just an example, as I said use the aromasin and save the clomid and dex for pct. The letro would probably be enough but if you had problems before definitely run aromasin every 3rd day and some letro if you have to
02-10-2019 07:46 PM #6
Bookmarks
