Results 1 to 6 of 6
  1. #1
    Ancillaries and Front Loading
    Hey JM,
    Looking for some answers. I've spent a lot of time the last two weeks regarding front loading procedures.
    I feel comfortable regarding my plan for the upcoming test e and tbol cycle. Then the use of steroid calculator I've selected levels that I am comfortable with to maintain blood levels throughout the duration of the cycle.
    However where many websites or articles fall short is the mention of AIs when front loading. Or if it's even necessary if one has not had issues in the past.
    My question is the following.
    I'm only running 500mg a week. Broken into 2 x 250mg
    10 week cycle.
    Front load 750mg
    Pin twice weekly 250mg Sunday / Thursday.
    Last week run a short 50mg a day tbol run to keep things moving into pct.
    Now. I did not have any issues with Gyno etc the first run. However I did have a big issue with estrogen rebound. I have aromasin now included into my pct to combat those issues.
    If I did not have issues before, do I need to run an AI as a precaution or is it a better idea to see how my body reacts?
    On hand I have letro, aromasin, clomid and nolvadex. However most of the above are set aside for pct. Yet that doesn't mean I can't put this cycle off a few weeks if need be to get more of what is needed.
    Thanks for your time. Hopefully this thread will get some informed responses from the experienced users on JM. My guess is others have had the same questions at one time or another.
    Cheers.
  2. #2
    Great one!
  3. #3
    You have way more than what you need for pct. So if a problem arises just hit the letro or AROMASIN for a quick knockdown
    Sent from my SM-G960U using Tapatalk
  4. #4
    Quote Originally Posted by lostcause75 View Post
    Right......
  5. #5
    Quote Originally Posted by Derek Wilson View Post
    Right......
    I use aromasin every 3rd day 12.5mg. For pct I just use novladex and clomid. This cycle was 600 testE 600EQ 600deca 50dbol/anavar daily weeks 1-6. Just an example, as I said use the aromasin and save the clomid and dex for pct. The letro would probably be enough but if you had problems before definitely run aromasin every 3rd day and some letro if you have to
  6. #6
    Thanks for sharing!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
