100-Rep Sets
  • 100-Rep Sets
    In honor of NLN and his 100rep leg press workout today,I figured id post this up.........
    100-Rep Sets
    By Greg Merritt
    How to use marathon reps to fast-track new gains.
    One hundred. It’s crazy, right? It’s the length of a football field in yards. It’s a century. It’s enough miles per hour to earn a painful fine. In those contexts, it’s big. But in regard to reps per set, it’s huge. Dorian Yates didn’t do 100 working reps in an entire workout! You may not have ever considered cranking out a set of 100—until now.
    The training style popularly known as 100s targets slow-twitch muscle fibers and permanently enhances blood flow to your muscles. In other words, it’s a unique and effective means of boosting growth. And there’s nothing crazy about that.
    THE CENTURY CLUB
    Rory Leidelmeyer, one of the best bodybuilders to never turn pro, used a 100s program for extended periods. Another top ’80s amateur who barely missed a pro card, Tom Touchstone, followed Leidelmeyer’s lead, as did Diana Dennis, who finished third in the 1985 Ms. Olympia. More recently, 2004 NPC Nationals winner Chris Cook plowed through a 100-rep shock set of curls and another of pushdowns on a non-arm day to drive blood to his arms and aid recovery. And Moe El Moussawi, who finished ninth in the 2008 Mr. Olympia, performed high-rep and high-volume training for years, including many sets in the 50-100 range.
    Okay, so some famous and semi-famous bodybuilders repped out marathon sets. But does it work? And if so, how does it work? Advocates claim it boosts growth, enhances vascularity, and brings a subtly different look—more detailed, more distinct—to their muscles. Think of the constant polishing of a diamond to enhance its shape. Marathon sets thoroughly stress a muscle’s slow-twitch fibers during the slog of the initial approximately 50 reps. But they tax fast-twitch fibers, too, as you approach failure points on your way to the century mark. High reps also enhance circulation to the targeted muscles. In turn, improved blood flow better feeds your muscles with growth-inducing nutrients.
    There are two ways to join the Century Club. You can do an entire program consisting of only three or four 100-rep sets per body part. Stick to this for periods of two to four weeks, and follow it with at least 10 weeks of a traditional workout regimen. This is a full-body growth turbocharger. Your strength may be a little depressed when you return to moderate reps, but it should bounce back within a couple of weeks.
    Alternately, you can work 100s into your usual routine as a shock treatment. Do an occasional century set session for a lagging body part, or rotate such workouts so that all body parts get the treatment from time to time. Not only can this jump-start new growth, but it can also recharge your training in general, especially when you have nagging injuries. Don’t have time for your usual workout, or your joints are still reeling from your last one? Do one set per exercise for 100 reps. Such a routine will be faster and also allow you to train around injuries. You may look a little crazy and a lot weaker doing marathon sets. But, if used only occasionally, 100s is a smart way to foster heavyweight gains.
    100-REP BASICS
    Select three to four exercises per body part. Do only one set of 100 reps per exercise. Warmups are unnecessary.
    Ideally, you want to reach failure at between 60–70 reps. Then pause and continue. Pause as many times as necessary to get to 100 strict reps.
    Use a weight that is approximately one-third of your 10-rep max. So, if you normally max out at 225 for 10, use 75.
    Pause for as many seconds as you have remaining. So if you get 64 reps, rest for 36 seconds. If you then get to 89, rest for 11 more seconds.
    100-REP TIP SHEET
    Either count out the seconds of rest periods, use the second hand of a clock or watch, or have a partner time them with a smartphone.
    Set down or rerack the weight during lengthy pauses.
    When you can get more than 70 reps without pausing, move up to a heavier weight.
    Choose bilateral exercises, so you don’t need to do 100 reps for each side separately.
    100-REP ARM WORKOUT
    Lying Triceps Extension: 1 set, 100 reps
    Smith Machine Close-grip Bench Press: 1 set, 100 reps
    Pushdown: 1 set, 100 reps
    Barbell Curl: 1 set, 100 reps
    Seated Dumbbell Curl: 1 set, 100 reps
    Preacher Curl: 1 set, 100 reps
    Sets (to failure) of 10 reps will build strength.
    Longer sets, performed at high imtensity, build power. Intensity is increased by performing an exercise at speed; air pressups (clapping at the top of each movement) are a high-intensity variation of the exercise.
    Sets as long as 100 reps will mainly build endurance, but all these effects overlap to some extent, so you will get stronger with 100-rep sets, or even sets of 1000.
    However, you will exhaust yourself quickly with high-intensity or high-resistance sets.
    10 sets with moderate intensity/resistance, or fewer than 5 at maximum effort, is a more realistic target.
