Workout Ive Used with Success.
  • Workout Ive Used with Success.
    Here's a 5 wk workout routine ive used through the yrs with great success.Its a 5 day a week mass building routine with 2 rest days at the end that has worked for many people ive had try it so if you guys are looking for a new routine that you may not have used before,give this one a try.
    Monday Workout:
    Flat Bench Press--------------------------2 Rest Pause Sets of 3,3,3,3,3. (Use a weight that you can perform 5 strict reps for and do only 3 reps,rest 20 seconds and continue like this until you've done it 5 times.Rest 3 minutes than run through it again.
    Smith Machine Incline Bench
    -----------2 Rest Pause Sets of 4,4,4,4,4. (Use a weight that you can perform 7 strict reps but do only 4 and continue as above.
    Decline Bench Press
    --------------------2 Rest Pause Sets of 5,5,5,5,5. (Use a wt that you can perform 9 strict reps but do only 5 and continue as above.
    Pec/Dec Flyes
    ---------------------------2 Rest Pause Sets of 15,15,15.(Same as above with 9 rep wt max)
    Cable Crunches
    ------------------------4 Rest Pause Sets of 15,15,15,15.
    Floor Crunches
    ------------------------3 Rest Pause Sets of 20,20,20.
    Tuesday Workout:
    Bent Over Barbell Row------------------------2 Rest Pause Sets of 3,3,3,3,3. (Same protocol as above)
    Wide Grip Ft Pull Downs
    ----------------------2 Rest Pause Sets of 4,4,4,4,4.
    Seated Cable Row-----------------------------2 Rest Pause Sets of 5,5,5,5,5.
    Straight Arm Pull Downs
    ---------------------3 Rest Pause Sets of 12,12,12.
    Donkey Calf Raises---------------------------4 Rest Pause Sets of 15,15,15,15.
    Seated Calf Raises----------------------------3 Sets of 15,15,15.
    - - - Updated - - -
    Wednesday Workout:
    Seated OverHead Barbell Presses
    -------------------2 Rest Pause Sets of 3,3,3,3,3.(Same Protocols as above)
    Barbell Upright Rows
    --------------------------------2 Rest Pause Sets of 4,4,4,4,4.
    Machine Lateral Raises
    ------------------------------2 Rest Pause Sets of 5,5,5,5,5.
    Reverse Pec/Dec Flyes
    ------------------------------3 Rest Pause Sets of 12,12,12.
    Dumbbell Shrugs
    ------------------------------------2 Rest Pause Sets of 4,4,4,4,4
    Cable Crunches
    -------------------------------------4 Rest Pause Sets of 15,15,15,15.
    Floor Crunches
    ------------------------------------3 Rest Pause Sets of 20,20,20
    Thursday Workout:
    Smith Machine Squats
    ----------------------------2 Rest Pause Sets of 3,3,3,3,3.
    Leg Presses
    ----------------------------------------2 Rest Pause Sets of 4,4,4,4,4.
    Leg Extensions
    ------------------------------------2 Rest Pause Sets of 5,5,5,5,5.
    Smith Machine Romanian Deads
    Lying Leg Curls
    -----------------------------------3 Rest Pause Sets of 5,5,5,5,5.
    Friday Workout:
    Standing Barbell Curls
    Incline Dumbbell Curls
    Machine Preacher Curls
    Close Grip Bench Presses
    ----------------------2 Rest Pause Sets of 3,3,3,3,3,.
    Triceps Dip Machine
    Tri Press Downs
    Donkey Calf Raises
    Seated Calf Raises
    -----------------------------3 Rest Pause Sets of 15,15,15
    Rest Saturday & Sunday and repeat this workout for 5 wks.Increase weight as you can but stay to the protocol as described.3 minutes rest between rest pause sets for larger muscle groups and 2 minutes for smaller ones.
