A beginner's help
  • A beginner's help
    I wanted to know whats the best begginner stack for me
    height :5'10
    Weight: 195lbs.
    I want to add more muscle size in mass and gain strength as well
    At the age of 24, you're runnin the best stack now. At your age, you have the highest amount of test in your body, you really should take advantage of that first before ruining yourself with gear. I would advise you not to start gear until your 25-26 years old, but I'm not your father either.
      You should run a solid PFC Stack ED and combine it with RHT EOD !
        please explain this....
        PFC Stack ED, RHT EOD....you know for the newbs if you can stand it?
            A solid stack which contains Protein Fat Carbs (PFC) every day and Really Hard Training (RHT) every other day.
              I'm curious what you mean by the statement, "ruin yourself with gear?" If it ruins you why are we taking it? I'm a newB too, and am starting my second cycle New years.
                Because you fucking your whole body up with gear. If you start with moderate testosterone only you will reduce your collagen synthesis by 80% which means your joints will start hurting some years from now. You fuck your axes up also. Yes you can counter all problems that gear does to you, but that will cause new problems. And why we are doing this? Because we dont want to be that fat ass idiot sitting behind his desk and awaiting his death... McDonalds will kill you faster than gear, but gear also takes some of your lifetime. Especially if you are doing it without respecting the potency. You should really do more research before starting your second cycle....
                  KongJitz, I said this because at Darnell11575's age, if he starts gear now it may shut his natural test production down, at this early age. If this does happen he will need to be on TRT (Testosterone Replacement Therapy) for the rest of his life. Now, you definitely get shut down during a cycle. This is why we do a PCT, to try and get our own Test back up and running. Most of the time this will happen, but in some cases some guys will not make it back after a few cycles. I'm not just talkin out my ass, I know this because it happened to me. Although I didn't start until my mid to late 20's but it shut me down around the age 35-37 years old. It took a few years to shut me down, but this is not the case for all, it could happen a lot earlier, I finally had enough of the way I was feeling, so at the age of 43, I went to my Doc and I told him everything, that's when he told me that I was shut down from the use of steroids. I've been on TRT from that point on and I'm 51 now.
                  So, this is just one reason that I would like to see guys at his age wait and not start AAS until there in there mid to late 20's.
                    Listen to MrBig!! He is the man and definitely knows what he is talking about!! Solid advice bro!
                      Well I think here are some guys who know what they are talking about. I started accidentially at the age of 14 with gear. It was a supplement called Stanozolon 2 from PharmTec/SledgeHammer, which was dianabol I think. This is 19 years ago and ofc my levels are fucked. But the TRT is not the main problem I think... Its all the other side effects which will sooner or later occur.
                      So pls dont just take AAS because its hip to be athletic and you want to take a shortcut. Make sure you know what you are doing and be aware of the consequences.
                        Can't a person run a lighter cycle that will actually help callogen synthesis? Something with normal test levels. Like 250mg week test(normalish level of test), with like 500 mg a week deca? From what I've read you can increase callogen syn, and get some solid gains this way. Seems like it would easier to recover from, and give your joints some love instead of tearing them up. I have no plans to run a high test cycle ever I my life. I'll never go above 500mgs in a week. because although I want to be althetic as long as possible, my long term health is important to me as well. Good to see the bros care!
                          KongJitz,
                          NO!!!
                          Even a little will shut you down completely!!!!! Think about what you just said, you want to run a "normal level" if you put a normal level of a synthetic Test in your body, your body will still act as if it has enough Test and will shut down. with a question like that, you REALLY NEED TO DO SOME RESERCH on AAS. All the questions you have, have already been asked and answered here, you just have to search for them. Don't be lazy, if your lazy with your research, you'll be lazy with your cycle and you'll end up with no gains at the end of your PCT. PLEASE know what your doing before you even start to place an order or use!
