Low dose of testosterone plus a couple of oxandrolone tabs
  • Low dose of testosterone plus a couple of oxandrolone tabs
    Low dose of testosterone plus a couple of oxandrolone tabs just as effective as a megadose of testosterone!!
    If you get men to train for 20 weeks and inject them with 600 mg testosterone enanthate, they’ll gain 8 kg extra fat free mass, according to some studies. But it’s possible to make the same gains with less, doctors at the University of California discovered. You can achieve almost the same results with a light course of oxandrolone and testosterone enanthate, and you only have to take them for 8 weeks.
    In 1999 the researchers published the results of a trial in the prestigious JAMA. It was a reaction to studies in which researchers had given HIV-infected men heavy doses, such as 600 mg nandrolone decanoate per week. The HIV subjects also did weight training. The researchers don’t think high doses are necessary. So they decided to do a trial using 22 HIV patients, giving some 20 mg oxandrolone daily, and all a weekly 100 mg injection of testosterone enanthate. The course lasted 8 weeks.
    The men did 1 hour of weight training 3 times a week. Under guidance from a trainer they did 6 basic exercises for the main upper body muscle groups and 3 exercises for the lower body. They used weights that were 80 percent of the weight at which they could just manage 1 rep [1RM].
    Eleven of the men were given a weekly injection of 100 mg testosterone enanthate and took a placebo. The other eleven men were given 20 mg oxandrolone each day.
    The figure below shows that the oxandrolone group had gained almost 8 kg fat free mass after 8 weeks. (1)
    The men in the oxandrolone group also gained strength faster than the other men. The gain in maximal weight for the bench press and the leg press was 10 and 20 kg respectively for the placebo group. For the men in the oxandrolone group the figures were 20 and 30 kg.
    The men in the oxandrolone group also lost a few ounces more fat than the men in the placebo group.
    So it’s not necessary to do a 20-week course of 600 mg to gain 8 kg fat free mass, the researchers conclude. It’s possible to achieve the same results with lower doses.
    But even the mild oxandrolone-testosterone course was not without side effects. In the oxandrolone group, 1 patient had to stop when his liver started acting strangely. Analysis of blood samples also indicated that the addition of oxandrolone to the modest testosterone course reduced the body’s endogenous testosterone production even further. The oxandrolone group’s LH and FSH production also decreased by more the researchers discovered. FSH and LH are hormones that stimulate the testes to produce testosterone.
    Some of the men were also taking retro-viral medicines, but these did not influence the effects of the steroids.
    "The combination of resistance exercise with a moderately supraphysiologic androgen regimen that included oxandrolone resulted in significantly greater increases in lean tissue and muscle strength than resistance exercise with physiologic testosterone replacement alone in eugonadal HIV-infected men with prior weight loss", the researchers conclude. "The use of protease inhibitor therapy did not affect the lean tissue response".
    Source:
    JAMA 1999 Apr 14; 281(14): 1282-90.
    More:
    The effect of 600 mg deca a week 21.02.2010
    Main side-effect of oxymetholone is reduction in HDL 27.09.2009
    Higher testosterone doses: more effect on muscle mass and few side effects 23.09.2009
    Testosterone riskier for fat men with short andro-genes 22.09.2009
    Four percent of bodybuilders go off the rails on 600 mg testosterone cypionate a week 10.09.2009
    Testicle size worries? Try a course of Nolvadex + Andriol 20.08.2009
    Higher doses of testosterone, less fat 17.08.2009
    Striant less efficient than testosterone plaster 11.08.2009
    Testosterone plaster makes women more muscular 22.07.2009
    Testosterone helps depression 08.06.2009
    Six weeks of testosterone-enanthate: more weight on the bench, faster sprint, often not detectable 12.05.2009
    ‘Right’ gene lets you inject testosterone without getting caught by doping test 25.04.2009
    Average meal gives optimal Andriol uptake 14.04.2009
    1975 study: bodybuilders grow with 10 or 25 mg dianabol per day 13.04.2009
    Study: testosterone works better than deca 29.01.2009
    Medical study: twelve weeks on oxandrolone 21.01.2009
    Medical study: twelve weeks on deca 15.01.2009
    Testosterone doesn’t make everyone a jerk 17.12.2008
    Recovery from mild nandrolone use takes six months 13.12.2008
    Hardcore (labs) 2 the bone
    interesting thanks
      I find that hard to believe. 8 kilos is 17.5 lbs. in just 8 weeks. I would be willing to bet that most of the gain was just water retention. Another possibility was that these people were very emaciated and were just gaining back their normal weight. In any case this has almost no relevancy to a bodybuilder who has experience with these drugs. You can't believe every thing you read.
        It's still a study....
          Almost all bodybuilders know the synergistic effect of an injectable with an oral, much more growthfactors. Just remember the dianabol/deca combo of the bodybuilders of the Golden era
