View Poll Results: Best Test to Tren ratio for effecting cutting/less sides?
Voters
1. You may not vote on this poll
  • High Tren / Low Test
    0 0%
  • High Test / Low Tren
    1 100.00%
Results 1 to 6 of 6
  1. #1
    Test E 250mg / Tren E 400mg for Second Cycle?
    Stats: 25 y/o, 5'9, 190lbs @ 12%, training for 8 years, solid diet/training
    Looking to run a my second cycle with Test E @ 14weeks / Tren E @ 12weeks to cut down..I had zero side effects from my first cycle. After research it seems it would be better to run Test E at a TRT dose of 250mg a week and run Tren E higher for less sides and makes the Tren E more effective.
    First Cycle: 6 weeks - T-Bol @ 60mg / 14 weeks - Test Cyp 250mg pinned 2x a week
    PCT: Nolvadex @ 20-20-20-20 / Natural T Booster
    Support Ran Throughout: 12.5mg Aromasin E3D / Cycle Assist Detox
    Planned Second Cycle: 14weeks Test E 125mg Pinned 2x a week / 12weeks Tren E 200mg Pinned 2x a week
    PCT: 10 Day HCG Blast @ 500IU / Nolvadex @ 20-20-20-20 / Natural T Booster
    Support Ran Throughout: 12.5mg Aromasin E3D / Caber @ 0.5mg E3D? / Cycle Assist Detox
    1. Would the current dose be effective?
    2. Caber 0.5mg @ E3D or E5D?
    3. PCT starts 2 weeks after last inject...10 day HCG blast starts after last inject...this good?
    4. 12 weeks of Tren enough or too much? is HCG needed as tren really shuts users down?
    5. Is this too much for my second cycle? it totals 650mg of gear..
    6. Should I add 6 weeks T-Bol kick start? or with 8 weeks Anavar ?
    btw i could never run tren ace doing 2x pins a week is hard enough lol thanks for any help!
  2. #2
    If your set on running tren for a second cycle, I would go with A instead of E. Ester clears the system faster in case you are not tolerant of tren sides.
  3. #3
    Quote Originally Posted by stallion View Post
    It would be nice but theres no way i could do more then 2x pins a week lol :\
  4. #4
    In my opinion you should hold off on the Tren E for at least a few more cycles. I have run Tren E a few times in the past and the sides can be a bitch. Just think it through. It may not be worth it. Also in my experience you should run the Test E higher than the Tren E.
  5. #5
    I agree with faith2002 u should get a few more cycles in before u run tren
  6. #6
    Quote Originally Posted by DontTazeMeBra View Post
    What is your goal with the HCG blast?
    "Whatever we plant in our subconscious mind, and nourish with repetition and emotion, will one day become reality."
    NapsGear.Org - The Largest and Most Trusted!
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
