It is a drug or a supplement regimen, that is used after a cycle, to restore yourn own production of hormones, (testosterone). This is more important then your steroid cycle. Given the thought your going to do a/s anyways. In other words a real cycle includes PCT, no if ands are buts and here's why. Other then restoring your own productions, it will help YOU RETAIN MOST OF THE GAINS YOU MAKE. Keep in mind when your taking testosterone, or products that convert to testosterone. Your body stops producing altogether. So what happens in between you taking testosterone and then when you stop and your own body has not yet begun to produce it. You may lose weight, no sex drive,gain water, body fat, depression, no motivation. So if the lack of testosterone don't rob your gains the lack of motivation will.
There plently of infom on PCT, here at JM. Take your time and read it over. It'sn worth your time.
IM NOT A DOCTOR NOR DO I PUSH THE USE OF ANY ILLEGAL DRUG. CHECK CITY, STATE AND COUNTRY LAWS. Think SAFE1.
