Are you looking forward to learning how to Ancestry Merge trees into one master tree? Then you have come across the perfect blog, as here you will find just what you need to know; you just need to read along to get started.
To begin with, you should know that the problem with merging two trees is that you would probably lose some data and relationships between people in the merged tree. Hence, the solution is to keep one tree as a ‘Source’ tree and then connect the other to it instead of joining them. Doing so will let you have both trees available if you need to go back and research.
Read full blog: Ancestry Merge trees
