The Linksys RE6400 extender is a powerful gadget that enhances the newest and most reliable technical characteristics. Regarding its specifications, it is compatible with both the 2.4GHz and 5GHz bands. The extender can offer up to 1200 Mbps internet speed without any interruptions or drop-downs because to these frequency bands. This extender's two removable antennae help to boost internet signals in any room of the house. For improved performance and WiFi coverage, it can operate in access point mode after setup.
In summary, it features a light indicator on the front panel that indicates how well it works and how strong the connection is. On the other hand, the Linksys RE6400 setup can be easily completed by using the reset and WPS buttons located on the side panel. Additionally, pressing the reset button returns the extender to its factory default settings by wiping out its customized settings. Finally, an Ethernet port for connectivity is located at the bottom panel. This allows you to make a wired connection between your device and the extender. Therefore, you can trust on these Linksys RE6400 extender specifications and product overview.
