superdrol
  • superdrol
    like to know if any body has tried superdrol and how it works as how good it is.
    I have not tried superdrol but my buddy has. I have heard that a lot of the gains is water weight but if you run it with a test base, it will help solidify the wet gains. I am not too sure though.
    Obsessed is a word the lazy use to describe the dedicated
      blew me the f up, strength and size. i will be using as a kicker for aas cycles.
        Yea i want to try it. Did the size stay are what bro like to know how would you run a cycle with that.
          Most size will stay if you PCT right and eat and train right. SD used as a kicker is sup to be decent and the test will help solidify gains.
          I did 4 weeks of 10/20/20/20 and started feeling better recovery in 2-3 days and strenght in about 5 days with size within a week. It works fast!
            so you used test e or test b and would you use deca to.
            what pct would you do with this cycle .
            BIGE
              Used super dmz with good results. Suppose to convert to sd and dimethazine once ingested.
                I have some on the way, and I was thinking of running it 4 weeks while running Testanon 250. Maybe throwing some tren a in the back end of cycle. Probably won't run until fall time.
