Arimidex or Letrozole..how much..??
  • Arimidex or Letrozole..how much..??
    How Much Arimidex or Letrozole Is Needed on a Testosterone Cycle?
    May 23, 2011 By Bill Roberts Leave a Comment
    Q: What dosage of Arimidex or Letrozole should be used for estrogen management on a testosterone cycle? I’m running 700mg of testosterone propionate per week and want to keep my estrogen levels in the low-normal range.
    Bill Roberts: For both letrozole and Arimidex, dosing really should be adjusted according to blood tests.
    Initial values to try, I figure a base of 0.36 mg/day for letrozole where no testosterone is being taken but there is a need to reduce high or moderately high estradiol OR 0.36 mg for each 200 or 250 mg/week of testosterone that is being taken, but not more than 1.0 mg/day as the initial value and typically not as an adjusted value either.
    The numbers don’t need to be that precise. The 0.36 value results simply from 2.5 mg/week being divided into 7 parts.
    Dosing also can be every other day instead of daily, provided the total weekly dosage is the same.
    With Arimidex I never developed an adjusted-for-testosterone-amount method, but have recommended 0.5 mg every other day and adjusting from there. This also works.
    For your proposed cycle, it would be the 1.0 mg letrozole per day figure, as 700 mg/week is about 3 times the 200-250 mg/week figure, and multiplying 0.36 mg by three gets us up to the 1.0 mg/day suggested initial-dose ceiling — but there should be a follow-up test of estradiol levels. Or if not doing that — the test isn’t expensive though and results are back quickly — then at least being ready to reduce if there are symptoms suggesting low estradiol: joint problems, depression, or low libido.
    But it is better to get the actual test because the absence of those symptoms doesn’t prove that estradiol hasn’t been driven too low. There could still be a problem.
    And likewise, having one or more of those symptoms doesn’t prove estradiol has been driven too low, either. It is only suggestive. But if one finds from experience that changing aromatase inhibitor amount clearly matches up with change in the symptoms, then that is a good basis for adjustment. Still (repeating myself) better to get the test.
    Read more from the MESO-Rx Steroid Forum.
    About Bill Roberts
    Bill Roberts+ received a bachelor degree in Microbiology and Cell Science and completed the educational and research requirements for a PhD in Medicinal Chemistry. His education was not specifically "geared" toward androgens other than expertise with pharmacological principles having broad applications. This has allowed Bill to provide unique insight into the field of anabolic pharmacology with knowledge of points which he would not have known otherwise.
    More Posts (98)
    one-more
    test
    Dosages of medications used on testosterone cycles can vary depending on the individual's specific needs and the goals of the cycle. It is crucial to consult with a healthcare professional or a licensed medical practitioner before starting any new medication or testosterone cycle to determine the appropriate dosage for your particular case.
    TechAdmin
    Administrator
      It is important to follow up with a test of estradiol levels and adjust the dose accordingly to avoid symptoms suggesting low estradiol (joint problems, depression, or low libido). It is better to get the actual test because the absence of those symptoms doesn't prove that estradiol hasn't been driven too low, and having one or more of those symptoms doesn't prove estradiol has been driven too low either.
      TechAdmin
      Administrator
        Even if you experience some or all of these signs, it does not mean your estradiol levels are dangerously low. It's all in the subtext. A useful starting point for adjusting aromatase inhibitor dosage is the observation that doing so correlates with observable improvements in symptoms. Still (to be redundant), passing the exam is preferable.
        TechAdmin
        Administrator
          Go see a doctor. Using too much or too little medicine can cause side effects or not achieve the desired effect. We won't know exactly how much we need heardle
