Any results as of yet? Just receieved QDL tbol, dbol, var, adex. Thinking about getting there Test E and EQ. Any reviews yet too?
Testing Quaility Labs?
QL
Yes we did some analyses, but if I present the results i want to be certain that I have the correct results. They have something in their carrier that shows the solvae but also shows a peak (15.8 minute) that is present in all analyses and is according to the lab present in the carrier. As far as i can see now its guaiacol, but I need info from the manufacturer about their carrier to prevent endless (expensive and time consuming) analytics. The samples I received and posted pictures of, where QDL Naps told me, thats why I tagged the reports with that name.
The active ingredients in the testosterone series where outstanding.. the sustanon was mixed up.
I'll spare you all graphics of the sustanon this is the labconclusion
Analysed Sust 250 and tried to identify the unknown peaks:
Sample should contain: - Testosterone propionate 30 mg/ml
- Testosterone phenylpropionate 60 mg/ml
- Testoserone isocaproate 60 mg/ml
- Testosterone decanoate 100 mg/ml
Sample contains: - unidentified Substance ? mg/ml
- Testosterone propionate 57.2 mg/ml
- Testosterone isocaproate 58.6 mg/ml
- Testosterone cypionate 97.7 mg/ml
Unfortunately I couldn't identify the peak at 17.65 min. in the sample. It seems they mixed up everything… Chromatograms of the single references, spiked sample and pure sample are attached.Last edited by RonnyT; 03-09-2012, 07:04 PM.
chromatograms
Originally posted by 1tuffcookie View PostI must have been asleep during that science class, Ronny can you translate that into english for us chemically challenged individuals like myself.
You owe me
I most certainly do Ronny Thanks. I just ordered they're Deca and cut stack just hope they are consistant with their gear... Ronny again thank you for your researchLast edited by 1tuffcookie; 03-10-2012, 01:21 PM.
Hey Ronny,,,question...if purity is good with respects to test. levels...what can this other peak do to usage of the gear, I mean how does this effect the quality of the gear as opposed to a different gear that does not have this additional peak...??? Can it be bad, as far as heavy metals etc.. just wondering...I know you don't have all the info yet, so probably hard to give a difenitive answer huh....?test
Originally posted by Liquid View PostYou'll be very satisfied, bro.
Originally posted by Liquid View PostQD is top notch
Will be interesting to see what's in their carrier. First quad pins of sus damn near crippled me for 5 days. I've had issues with shorter esters b4, so i'm not terribly worried , but switched to the test e and had no issues.Employ your time improving yourself by other men's writings so that you shall come easily by what others have labored hard for. -Socrates
