Nipple Tenderness
  • Nipple Tenderness
    Ok so my cycle was 525mg test prop per wk & 350mg npp per wk. for the first 4 weeks. Now, due to pretty harsh PIP (i'm one of those that dont react well with prop actually used two different companies prop and had similar reactions, its me not the gear) so im doing 100mg prop, 125mg enanth, 150mg npp E2D as well as 300ius of hcg per wk. As well as 35-40mg of dbol ED, I am also running .5 adex from our sponsor (everything is from our sponoser besides npp) and my gyno has started to flare up. Tissue has increased a bit from what is was. Nipples are more tender & sensitive. I have letro on its way but i don't want to resort to that because I know there should be some estrogen in the body to make gains. Now my question is, should i up the adex dose to .5 ED/ 1mg EOD? or maybe even more?
    thanks bros for your input.
    -MB
    Hey bro. If you break it down you are doing test, deca (albeit fast acting), and Dbol up to 40mg/day.
    I think a low dose of nolvadex should control nipple tenderness. .5 adex ED should be more than enough.
    I don't know how lean you are, but I used to mistake a little pudge for gyno. Good luck !
      yea, I realize its a pretty common cycle for nipple irritation. last i checked 3-4 weeks ago i was 8.5% and i havent put on an insane amount of weight. Not nearly enough where i want to be. Im naturally an ectomorph and a very hard gainer. the dbol is actually making more shredded. arms, shoulder, abs veins are back out in full force like they were when i was on test n winni. i actually wear sleeves in the gym now not to attract unwanted attention. There are ppl out there that dont approve, so i try to cover up with hoodie, long sleeves, or long short sleeves. anything that reveals my whole arm & shoulder i started to stay away from. I have enemies in my gym unfortunately. So its def not pudge, its gyno. remember i am using HCG, which can cause gyno flare ups and i had a bit of pre existing gyno from puberty that only grew a bit from last cycle.
        Sounds like you're growing nicely. I'm the pudgey one LoL
          yea, growing in my nips. think i might up my adex dose to .5ED but i always heard adex takes a bit to fully work. I dunno its from our sponsor so i know its legit, but im just in a tough spot. Might just hit it hard with letro, then switch to adex. gonna suck for those 1-2 weeks of 0 estrogen.
            Yes I've heard of Letro clearing it up entirely. ...And don't discount the old stand -bys Tamoxifen and Clomid, once it's under control.
            for cost effective estrogen control.
              not that i dislike nolva & clomid for estro control. adex & letro are just more effective drugs in that regard of gyno. apparently .5mg eod of adex wasnt enough, as much as nolva is used i really see it more as a PCT drug than estrogen control. i have nolva, clomid, adex, soon to have letro on hand, just not sure how to hit it, and at wat dose. anyone else give me their advice? maybe a vet?
                go ahead and start the letro, id start at .5 mg a day and slowly increase it until you are at 2.5 mg a day. run that until you are satisfied with results, then taper the dosage back down. is the letro liquid or pill? i used the liquid and i draw with a syringe, i go up 1 mark on the syringe, which is .25 mg. but if you got it in pill form, itll be hard to get the dosage lower than half the pill, which will prob be 2.5 mg per pill
                  alright, thanks PW I got liquid letro on the way. I just dont want to fuck up my libido, I have a Christmas party next week and trying to make a threesome happen Ill start letro treatment after that. Right now, libido is through the roof. actually gotta rub one out at work, thank god for lunch breaks.
                    lol, youre a wild man. letro can cause libido issues but it never has done it to me. could be bc ive never had to dose it too high. but anytime im running letro, i have cialis on hand just in case
                      LOL ... Letro will do the trick
                        Heh, yea im pretty much a walking boner at this point. No reason boners all day, which is good but when you have to give invoices to the account and walking around the office is a bit of a concern.
                          Ok so they say if you have an erection for more than 4 hours to call your doctor..........hell no, the only way I callin the doctor is if she's hot, other wise I'm going to enjoy a 4 hour erection!!! jm2c
                            LOL u crack me up bro
