Help With My Next Cycle
  • Help With My Next Cycle
    I'm look for everyones opinion, I'm wondering what would be the best way to run what I have, I'm trying to put size on, so do I go short cycle high dose or mid dose long cycle, or should I get some more or something else?
    Ok this is what I have:
    GP Test E - 30ml's
    GP Test C - 30ml's
    GP EQ - 30ml's
    GP Deca - 30ml's
    You could break that up into 2 different cycles. Test Cyp./ EQ or Test E./ Deca.
    The only thing with Eq and Deca is, You would wanna run them 16-20 wks. Some may disagree but I found that they really start working well around the 8 week mark. I like to run them alot longer especially Eq. As far as how many to get I like to over buy myself that way I have enough. I would look at getting at least 4 bottles of Deca/Eq. and It would depend on how many Mgs. of test you will run to figure how many bottles. But I would run 1 or the other in my opinion... Thanks buddy!!
      4 c's of test, 2 c's of deca, 2 c's of eq a week. what you have will last 15 weeks, woot!
        Is that based on spliting up those doses on a mon/thur schedule??
        So
        2 c's test
        1c deca
        1c eq
        mon and thur ???
          i just took what he had and split it up for a decent duration. you could run it anyway youd like, but mon/thurs would work fine. or you can pin alittle more often to get the amount each time down some
            I'm getting some more gear, so I think what I'm going to do is a 15 week run that looks like this:
            Test cyp 250, 60ml: 1000mg. wkly
            EQ 200, 40ml: 500mg. wkly
            Deca 250, 20ml: 375mg. wkly
              how many cycles have you done? ever done anywhere close to a gram of test a week before?
                Bump what PW asked? Whats your cycling history? 1g is a lot and should not be needed if your still fairly new to cycling.Ive been cycling for 20 plus yrs and am on a gram ew.
                I would also not run the eq and deca together.I would save on for another cycle.Its not needed IMO.
                Also,what do you have for pct and any ai during the cycle?
                  fist, why not run eq and deca together? i dont see a problem with it. but if mrbig does decide to change it up alittle, im running test/deca/mast right now. ive been pretty happy with the results from this one so far
                    Eq is Deca's little brother.. They operate off the same receptor... It'll be like running T-bol with dbol..... I would run one or the other in my opinion..
                      There's nothing wrong with it as far as neg sides but depending on how early he is with cycling,it may not be needed.If he's only done a couple of cycles,then he should stick with a basic cycle.The least amount of compounds the better.Thats all im saying.The longer you can run with the least amount of compounds and still make gains the better.In the same respect,the sooner you start adding compounds,the sooner you will build up a tolerance for them and need more in following cycles so why not ride it out as long as you can?
                        I actually get better results from EQ but like deca for the joint lubing qualities.I have run both at the same time before but not often.I have gotten great results from both as well but prefer EQ.Also,no risk of dead dick with eq.LOL
                          I didn't know that about the Deca, so I'm going to drop it. I've been using gear sence I've been some where around 30yo and I'm 48 now. The most I've done is 800mg of Test wkly (last summer), right now I'm on 400mg of Prop and 600mg of Tren E wkly.
                          Oh and for my PCT I'm just going back on my HRT.
                          MrBig
                            It looks like this is what I'm going to do:
                            1000mg Test Cyp wkly
                            400mg EQ wkly
                              400mg EQ wkly
                              I would either lower the test to 750mg or raise the eq to at least 600mg ew.Have you ever run 1k of test before? If not why not keep it lower and judt add the eq in? You should make great gains off of the 2 @ lower dosed test.
