Coach5's First Cycle Log
  • #16
    Good luck bud!
    • #17
      OK...my stuff is definitely legit....think I have a case of test flu.....2nd shot was earlier on Wednesday
      • #18
        Test flu? What brand are you taking? I've never experienced test flu, and from what I have heard from others, ones that suffer from test flu, is usually due to junk gear. I am interested to what others have to say about it...
        Also, make sure you have some Ketotifen for your clen.
        • #19
          I'm using GP.... I felt much better this morning....and it's also not a sign of bunk gear...it's a sign of your body trying to restore homeostasis from the excessive hormones. No need either for the ketotifen since I'm running the clen 10 on and 10 off.
          • #20
            subbed man!
            • #21
              Hows it goin man? Is the clen gettin any better??
              • #22
                Here is this weeks update...
                Weight= 241.4
                LBM= 201.0
                BF%= 14.58%
                Waist= 36
                Naval= 36.75
                Hips= 43
                Neck= 16.5
                Chest= 46.25
                Biceps= 15
                Forearms= 13.5
                Thighs= 25.5
                Calves= 17.75
                Before any of you start flaming me about my gains, let it be known that I am aware that Test-E will not illicit any gains for the first 3-4 weeks. I know that the increase in weight, LBM, and size is from the addition of creatine to my diet and the upped protein intake. I am taking 10g daily of creatine. Some of the weight I gained is also probably from me being constipated for the last 3-4 days.(Took laxatives this morning) I have noticed a lot more definition in my abs this week up until around Friday when my bowels decided to stop working. I will also add that my skin seems to be tighter and I'm more vascular too. I finally started noticing some effects of the clen this morning when I raised the dose to 140mcg. Tomorrow is my 10th day on the clen, but I may extend it out to 14 days since I'm just now reaching my target dose it seems. I will update again next Sunday.
                • #23
                  Sounds good man. You should log your lifts and loads so we can see strength increases if you got the time
                  • #24
                    Wow what a great log this is,, I need help coach5 or anyone please help me get the right cycle. I have been Declining in the gym and need a healthy bulk/ shredd cycle-- after ill be doing pct.
                    viper826@aol.com
                    • #25
                      Will try to start tracking this week unless it starts to slow my workout.
                      • #26
                        viper826@aol.com
                        If you've never done AAS before then all I would recommend is Test-E for 10 weeks @ 500mg/wk split into 2 doses. Take aromasin or arimidex while on cycle and clomid and nolva for your pct. As far as bulking or shredding...it's all about what you eat and how much you eat.
                        • #27
                          Thank you for your tips, I have done some research and have narrowed it down but between clomid and nolva what would be your prefer pick?
                          • #28
                            Use Both..
                            • #29
                              Originally posted by coach5 View Post
                              Use Both..
                              Check this out Nolva vs. Clomid ; http://juicedmuscle.com/showthread.p...t=CLOMID+NOLVA
                              • #30
                                OK...Quick update that I thought was important...
                                GP Test-E is G2G... Today is day 11 and I noticed last night that I'm starting to slightly break out on my face, neck, upper chest, shoulders, and back. Skin also feels a bit oily. I have never had a problem with acne before in my life, so I know this is directly attributed to the test-e. I guess it is time to start bathing in epsom salts frequently to help dry the skin out.
