3 Beginner Steroid Cycles That Will Pack on Muscle Fast!!
  • 3 Beginner Steroid Cycles That Will Pack on Muscle Fast!!
    [INDENT] 3 Beginner Steroid Cycles That Will Pack on Muscle Fast!!
    April 21, 2015 By John Doe
    You are asking yourself right now whether you should use steroids or not, and you have no idea what to use and how much. You want to stay safe and you want some solid results. What do you do?
    Well friend, that is totally up to you and your conscience. But chances are youre going to do it and I have enough articles already explaining the reality of steroid use, so lets assume you are going to do a cycle.
    Below are 3 different beginner steroid cycles that will pack on some good mass and are relatively safe.
    I dont advocate steroid abuse or higher dosing than necessary, so what youll see below are cycles that would be safe to use and more mild on recovery than much of what you may have already read out there, yet effective as hell at the same time!!
    Cycle #1- TESTOSTERONE ONLY
    Ive already talked about the 1 vial steroid cycle enough in the past, lets get into the beginner 500mg/wk test cycle.
    What youll need are 2/ 10ml bottles of testosterone enanthate or cypionate. Test E and Test cyp are ok to inject just once/wk so they are convenient and very effective. Also, testosterone is one of the less faked compounds out there, so chances are that what youre getting is real, unlike many other more exotic compounds on the market.
    The type of needles you want that are easiest and safe to use are 23 GAUGE/3ML/1″ syringes and they can be bought online if your local pharmacy will not sell them to you. Laws vary state to state.
    You will inject 2 ccs 1x per week for 10 weeks. You will inject into your butt cheek and the following week the opposite one. hen you stick the needle in, be sure to pull back on the plunger about 1/8 of an inch first, and if you see blood then do not inject because youre in a vein. Simply re-inject in a different area on the same glute.
    [SIZE=3]The test will take roughly 2-3 wks before it really starts kicking in
    F.I.S.T.
    Thank you. Might seem basic to most, but as someone that has been on the fence forever the more knowledge the better.
      Thats absolutely right Tooth.Knowledge is power as they say so the more we have the better off we are.
      This is only ones mans experience with it and what worked best for him so take it for what it is.Everyone is different and will react differently to any given stimuli so the ultimate factor in determining how it will work for you is through trial and error.Always remember too,that what works or doesnt work for you will not negate the experiences of others.Its a very individual thing.
      Thanks for the reply.
        Awesome info, thank you F.I.S.T. It sounds a bit silly to veterans but even the needle gauge is something that beginners wonder about. I didn't think about the difference of drawing oils verses hydrochloride. Great info man.
          My pleasure etchingbullet.
            Great article FIST, interesting. When I started out 2 yrs ago, I was using 200mg X 2 per week and began to get good results. Then a friend who's really built & another friend, both extremely knowledgable, suggested I add Deca to my test & took 200mg X 2 per week of that. My results were amazing & fast. I tried Dbol for a while & didn't get as good results or didn't like it for some reason. I keep a journal on this but forgot to put it in. I also tried Masteron with Cyp and didn't care for that. The Deca/Cyp stack seems best for me.
            My pharmacist suggested the 25 gauge needle which I've been using for a couple years. I looked up the difference between the 25 & 23 that you suggested, the inner diameter in inches seems negligible, but next time I'll get the 23. Test is very viscous & I have to inject 4-5 syringe full (3ml syringe) of air into the vial to get the test to fill the syringe easier/quicker. Also the injection takes longer because of the viscosity of the test, so an increase in the diameter of the needle should help. The 23 gauge has an inner diameter of 0.01325”; the 25 gauge has an inner diameter of 0.01025”, a difference that seems very small.
            Any comments or suggestions you have on any of this is greatly appreciated. Thanks.
              Been pinning for 3 decades brother and have NEVER had any issues with 23g.This being even though I use the same pin to draw the oil from multiple vials most times and inject with.
              Trust me,go with the 23g and you'll be happy.
              As for the dbol,I personally prefer drol over dbol hands down.Much better size and strength gains with no real negative sides.
                Great info....i track my macros.....I'm 5'9 amd 185 lbs.....i try to take in 200+ p 180 c 70 f.....should i stick to this or change something
                  First time I read this and I must say so simple basic but straight to the point. the Decca n dbol ya spot on if your not gonna gain on that you are not eating or training or your just bloody unlucky so keep your money in your pocket lol
                  Haters are always gonna hate. Your better being hated on than the one doing the hating love life live it.
                    sorry, i'll repost in a different forum...
                    bikerbum
                      Glad you found it helpful bigred.
                      Thanks for reading it and for the reply.
                        this is awsum bro much needed info bin serching for like 3hole days to finde somthing this strate forwerd thx
                          My pleasure doc45.Im glad you found it helpful.
                            "Cycle #2 – TEST/DBOL
                            Ok, so you’re dead set on a stack for a first cycle. Is it going to kill you to do a stack your first cycle?
                            No it’s not. Do I think it’s absolutely necessary? No I don’t, but if you’re trying to make damn good and sure you’re packing 20-25 lbs on the frame in something like 8 wks then be my guest"
                            Thanks F.I.S.T for a lot of great posts on here and for helping to educate everyone. My question is, if you don't feel a stack is necessary for cycle number 2, what do you feel would be a great second cycle without the stack of TEST/ DBOL? Especially if one followed a 1 vial test run and came away with some great results.
                            I completely agree with you that less is often more, especially when looking at the long term/ big picture.
                            Thanks again, and look forward to your response.
                              I'm also looking forward to a reply on this, just got done with first Test only cycle!
