The Pro Creator
By Hany Rambod
(APRIL 2008)
FST-7 ? the key to muscle growth
What is FST-7?
FST-7 is a training system I devised after years of research and a great deal of trial and error with many clients. FST stands for Fascia Stretch Training, and the seven refers to the seven sets performed for the final exercise of a target bodypart. I have had many clients use this system for overall growth and especially to improve stubborn bodyparts that were seemingly resistant to just about anything else the person had tried. FST-7 encompasses several factors both inside and outside the gym. This month we will focus on the training aspects.
Is fascia limiting your muscle growth?
There are three types of fascia in the human body, but the type bodybuilders should be concerned about is deep fascia. This is dense fibrous connective tissue that interpenetrates and surrounds the muscles, bones, nerves, and blood vessels of the body. The high density of collagen fibers is what gives the deep fascia its strength and integrity. The amount of elastin fibers determines how much extensibility and resiliency it will have. In other words, some of us have fascia that is thicker and tougher than others. The most genetically blessed bodybuilders have thinner fascia, which is why their muscle bellies appear to be larger and fuller, with that round ?bubbly? look that all bodybuilders covet. Ronnie Coleman and Phil Heath would be two prime examples of individuals blessed with thin fascia. Their muscles expand easier. Think of it in terms of it being easier to blow up a balloon as opposed to one of those water bottles that strongmen like Franco Columbu used to. Jay Cutler and Nasser El-Sonbatty are two men that clearly have thicker fascia. This didn?t prevent them from building substantial muscle mass, obviously, but neither man ever had that round ?Marvel Comics? appearance to their muscles. Yet the average bodybuilder has thicker fascia than either of those two champions. In an effort to expand their fascia and allow growth to occur, some have turned to Synthol and other items that are injected deep into the muscle belly. There have even been some advisors, mainly online, that make it seem as if this is the only solution and must be done. They will also try and insist that all the pro?s use Synthol and site inject, which I can assure you is not true. Synthol and related products are foreign substances, and you can never be certain how they will metabolize in the body. We are starting to see various health issues with bodybuilders that are more than likely related to site injecting. Yes, you do need to stretch the muscle fascia to experience optimal growth, but that is not the way to do it.
All stretching is not the same
I am not the first person to recognize the importance of stretching the muscle fascia. First John Parrillo, then more recently Dante Trudel of DC Training fame, incorporate aggressive stretching during workouts as part of their training programs. They had the right idea, but stretching the fascia by elongating the muscle is not the best method. FST-7 is based on stretching the muscle from the inside out by volumizing it. This is accomplished by getting the greatest pump possible while training.
Do I still train heavy, or can I just pump up with light weights?
One thing I don?t want anyone misconstruing is that FST-7 is all about pumping. That?s just one component. I also believe that a bigger muscle is a stronger muscle, and you absolutely must train with heavier weights in the 8-12 rep range. I have tried many variations of heavier and lighter training with clients over the years, and discovered that both types are needed. Heavy weights will build thickness and density, but they will not give you that round, full look. Similarly, getting incredible pumps all the time can impart some of that roundness, but you won?t ever get extreme muscle size without training with heavy straight sets. So you need to focus equally on maximizing both your strength and your pump in the same workouts to see optimal results. Here?s an example of a biceps workout, FST-7 style, that shows you how to incorporate both:
Alternate dumbbell curls 3-4 x 8-12
Machine preacher curl 3 x 8-12
EZ-bar curl 7 x 8-12 (rest 30-45 seconds between sets while sipping water ? more on this next month)
I don?t typically like to use very high reps, because too often you will experience general fatigue and get short of breath before you have built the maximum pump in the muscle. I also don?t like the weight to be too heavy and limit the reps any lower than eight, because this is when you see form breaking down and ancillary muscles kicking in and robbing the target muscle of the proper stimulation. You can think of the ?7? set as blowing up a balloon. We keep the rest periods fairly short, because as you pump up the muscle, a little blood escapes in that time. You can think of it as blowing up a balloon with a slight leak in it ? even though the balloon is being inflated, some air is escaping. The key is to build on the pump sets by set, exponentially, so that it reaches its maximum state by the final set. If the rest periods were too short, you wouldn?t have enough energy to do justice to the seven sets. Another question I often get is, should the weight be constant as the seven sets go on? It can be, but it?s perfectly fine to reduce the weight one or two times as needed to stay in the proper rep range. There may also be times when you need to increase the weight, but this happens less often.
How often can I train bodyparts this way?
Generally speaking, this type of training is too traumatic on the larger muscle groups to use more than once a week. Due to the sheer volume of muscle cells, soreness tends to linger too long to allow for more frequent workouts. For instance, Phil Heath recently completed a back workout and was sore for four days. Since he is supposed to be training back and chest twice a week in preparation for the Arnold Classic, this threw him off his schedule somewhat. The higher than normal amount of microscopic tears in the muscle caused by FST-7 training necessitates a bit more recovery time than standard training protocols. However, smaller bodyparts like arms and calves certainly can and should be trained twice a week. This gives you twice as many opportunities to stretch the fascia in what are often exceedingly stubborn bodyparts. Here?s a sample split that displays how you could arrange this:
Day one: Biceps and triceps, calves
Day two: Legs
Day three: OFF
Day four: Chest and triceps
Day five: Back and calves
Day six: Shoulders and biceps
Day seven: OFF
This is a split geared toward someone with the goal of improving stubborn arms. There are many other variations depending on what the individual?s goals might be.
By Hany Rambod
(APRIL 2008)
What is FST-7?
Day two: Legs
Day three: OFF
Day seven: OFF
