how to juice
  • how to juice
    I get a lot of p.m. visitor messages like this one. And I bet Sam does also Its also a favorite subject for threads, and even how much we would like to answer all of you up into detail, it is impossible, because verybody is unique, ans reacts different to juicing/eating/training, plus everybody has their own goals.
    RONNY,.can i add you as a friend and get some advice from you,on packing on mass,,,,i just ordered my gear,,2gp test enath250,,,,1gp deca250,,2gp turan,,3gp anastrozle with a protien intake,of 300-350 grams per day what should be my total calorie intake per day.......and how much clean weight do you think that i can pack on with this cycle...13 cycle,,,,
    I found a nice set of Q and A’s on the net and will share it with you folks Just to lazy/busy to write one myself..lol..
    you wanna learn about juice eh. Well the purpose of this thread is twofold:
    1. There are way too many "this is my first cycle, does this look ok" threads junking up the steroid page and they all get the same response so I am going to try to save everyone some time. Read it. Re-read it until you understand it so you don't waste people's time with questions that have been asked a thousand times.
    2. I would like to provide everyone that is trying to learn with a very quick and easy guide to understand how to put together a proper cycle that will match their goals. This is really the basis of what you need to know. My reasons are kinda selfish for this - I would like androgens to be legal for use (over the counter) in my country one day before I die; for this to happen we are gonna need to educate people so they stop fucking up and giving gear a bad name.
    PART I - YOUR FIRST CYCLE
    There seems to be two schools of thought on first cycles:
    One camp says juice hard your first cycle (about 1-1.5g/week), primarily test (500-1000mg/w) and then a secondary compound and orals to make up the rest because you will make you best gains on your first so you might as well max it out. My issue with this approach is there is a very high potential for things to go wrong so you need to be really well prepared, well educated about dealing with sides, and you need to trust your ancilliary source (to mitigate side effects).
    The other camp says use a moderate amount of test only *500-600mg/w) and use more test/different compounds on successive cycles to continue making gains. Save the Deca, Tren, Masteron, EQ, Winny, HGH, IGF-1, etc, etc that you have heard about to get more out of future cycles...chances are this isn't going to be the only cycle you run so add them into future cycles one at a time so you know what works best for you and you continue to see big gains in future cycles. They don't really work better than test, they just work different so you might as well start with just test to see how your body reacts to it...I will go over all the other compounds in the later sections so just forget about them until you understand this one.
    I am not sure anymore which camp I am in...I think the more conservative one just because it is an easier learning process and a bit safer but that is not to say it will produce better gains. That would require a lot more research of both protocols head to head.
    This is an ideal first cycle for everyone or at least a base to build on:
    (NOTE - W X-Y means start of week X to end of week Y)
    Cycle Plan
    W 1-10 Test Enth 250mg E3D
    W 1-12 Adex 0.25mg EOD (reduce to 0.125mg EOD in last week)
    This would be an example of a camp number 2 keep it simple cycle. You don't really need to get more complicated than this but if you want to below are some typical inclusions for a first cycle...
    Optional secondary additions
    W 1-4 Dbol 10mg 3x/d if you want an oral kickstart or just a little something extra thrown in mid cycle when your test is kicking in (seems most lately are going with the latter)
    W 1-8 Deca 300mg/w if you want some additional bulking help
    W 1-8 Tren Enth 150mg E3D if you want additional strength help
    W 6-12 Proviron 25mg 2x/d if you want some help with libido
    Optional Ancilliaries
    W 1-12 Nolva 20mg/d if gyno symptoms (itchy/tender nipples) start to show
    W 1-10 Caber 0.5mg 2x/w if you are having prolactin issues (difficulty getting an erection when on tren or deca)
    W 3-10 HCG 250iu 3x/w if you want to prevent your nuts from shrinking and make recovery easier
    Post Cycle Therapy starts week 13
    It is the same with either approach...you just have to make sure that your gear is cleared from your system before you start PCT (or it won't work because you will still be getting suppressed from the gear).
    PCT Option 1 (SERM PCT)
    W 13 Nolva 20mg 2x/d or Clomid 50mg 2x/d
    W 14-16 Nolva 20mg/d or Clomid 25mg/d
    PCT Option 2 (Test Stasis and Taper)
    W 10-12 Off (if your cycle was enth 2 weeks is enough to drop down to normal levels)
    W 13-14 Test Enth 40mg E3D (stasis portion to mimic normal hormone levels)
    W 15-16 Test Enth 30mg E3D (taper portion)
    W 17-18 Test Enth 20mg E3D
    W 19-20 Test Enth 10mg E3D
    The taper gradually takes your body below normal androgen levels slowly enough that it is able to kick in and compensate. There is a much more detailed explaination of this later
    Q.Why you would need nolva and proviron when you already run adex?
    A.You don't NEED them, that's why it says optional. Nolva is only if you are having estro issues and the proviron is just to make a little more productive use of the second half of your cycle by making more free test but it is not needed to run a successful cycle but it is a good option if you have it available. It also really cranks up the sex drive so that you can put that new muscle mass to use
    Now that you know what to take lets talk about who should cycle and what to eat and train.
    YOU SHOULD NOT CYCLE IF:
    1. You are under the age of 25
    The reason is that your natural test is still very high and you are able to make very good gains without gear. There is also a very good likelyhood that you are going to end up messing up your endocrine system because you are still in a period where it is fluctuating. If you are not making good gains you need to look at your training and nutrition. I personally waited until I was 27 to start taking gear even though I was ready to rock when I was 20 so I know how you feel but you need to trust that with proper diet and training you can make gains naturally. The rare exception is individuals with a lot of training experience in their teens who have already acheived a very high level of physical development (230lbs+) and is already at or near their genetic limit. If you are one of the rare individuals who has already reach a very high level of development through consistent training the absolute earliest you should consider gear is 20.
    2. You are over 25 but have been training less than 5 years
    If you have not been working your ass off in the gym for at least 5 years naturally with good nutrition you have a lot of natural potential left. It is best to exhaust as much of your natural potential possible before resorting to gear. Gear should be the final piece of the puzzle to your ideal physique. By gearing up too soon you may be short changing yourself.
    3. Your diet and training is crap
    Gear is not a magical pill. It makes hard work more rewarding, it doesn't give results for doing nothing. All you will get is some temporary water retention which will be gone when your cycle ends. Diet and training on gear is everything. Period. You should have a very good idea of what you are going to eat (including macronutrient breakdown) and what your training plan is going to be. If you aren't already eating properly you can make some very good gains by doing so first naturally. If you aren't already training properly you can make some very good gains naturally...make use of that then think about gear. This site has a wealth of info on both topics. If your training and diet is off you will just waste your money doing a cycle.
    4. You are a fat guy looking to get "cut", "ripped", or "shredded"
    If you are a big fatso and think gear is going to make you slim and jacked it isn't going to happen. Fatloss comes from proper diet and training. If you can't cut down without the gear you will have just as much trouble on the gear. If you are looking for something to aid fatloss try a fatburner and then add on muscle once you have cut down.
    It will look a lot more impressive and be a lot more successful....again this site has a wealth of info on losing fat...I highly recommend checking out the Velocity Diet that Gus is doing in the Physique Clinic...it shows what proper training and dieting can do. The anabolic diet is great for guys, I suggest checking it out as well because if you are fat you are likely fairly insulin resistant so cutting carbs will likely provide very damatic results. You get to eat a lot and because of what you are eating your natural testosterone will be high.
    Cutting cycles are run by vets that already know what they are doing, have diet and nutrition down, and are just looking for the last little tweak to their already lean physique. Once you have achevied that status you can look at cutting cycles.
    5. You are emotionally unstable
    Gear can mess with your emotions. If you are an unhappy/depressed person that thinks being geared up is going to make your life better chances are you are going to feel good for a little while when on and then when you come off you are going to be lower than when you started and likely downright suicidal.
    If you are a livewire that goes off in a rage when you drink, do drugs, or when someone pushes your buttons guess what? Gear is going to make this worse. If you have trouble controlling your anger then gear will make it more difficult. You will likely end up acting like a bit of a maniac and alienate your friends.
    If you have answered yes to any of the above 5 questions you are not ready for gear.
    Read this. Re-read this. Let it sink in. Then read everything in the Newbie thread stickied right beside this thread if you haven't already. Then come up with a plan that works best for you based on YOUR KNOWLEDGE OF GEAR. Post it on the board and get feedback once you know that you are serious and have most of the details figured out.
      PART II - LONG CYCLES (3-9 months or continuous use)
      WHO
      This is an approach often taken by those with a great degree of experience or older users that no longer have a need of their natural test (or who's natural test is too low to bother with as is the case with Hormone Replacement Therapy or HRT).
      PROS
      It is believed that longer cycles will result in more perminent gains because:
      1. The body has more time to adapt to the new muscle mass...this point is very debatable but the general idea is that the body has time to adjust the new 'set point' of mass.
      How it does this is not fully known and may be total speculation...I believe it has to do with satellite cells which will be discussed in more detail later.
      2. There is more time during the cycle to build muscle tissue. At some point (which varies from user to user but are generally around the 2-3 month mark with long esters) gains begin to diminish such that eventually little to no further gains are seen and the continued use is simply maintenance of the existing muscle.
      However with very long cycles some users are able to make continued gains either through very strict training and diet or the addition of peptides.
      Often times brief periods of high doses (blasting) are employed to see continued gains followed by long periods of low to moderate use (cruising). This allows users to break through plateaus that are reached when gains diminish to the point of little to no growth.
      CONS
      The biggest downsides are:
      1. Cost is increase with cycle length (obviously)
      2. Many side effects become more pronounced over time
      3. Shutdown is very severe such that to recover natural test (if coming off at all) is only posible with the use of HCG to stimulate the testes or by tapering with Test to try to allow the users HPTA to return to normal gradually. This is of course not an issue with continuous use because there is no need to recover if not coming off.
      PRIMARY COMPOUND
      Test Enth or Cyp is usually the only or at least the main compound for long cycles. This is because of:
      1. Effects on libido. Synthetic Test is the only compound that is a substitute for natural Test in this regard so it is really the only choice when shutdown is guaranteed if the user (assuming they are male) values their ability to get an erection and desire to have sex.
      2. Long half life (reduced injections and more stable levels). The Enanthate and Cyponate ester versions are most commonly used because injection frequency can be reduced to about once every 4-7 days.
      3. The even balance of anabolic to androgenic qualities.
      Here is a list of possible androgenic and anabolic qualities so you know what this means:
      ANDROGENIC (ANDROGEN RECEPTOR MEDIATED EFFECTS)
      - increased male charicteristics like agressiveness
      - increased sex drive
      - increased oil production
      - thickened face and body hair
      - growth of prostate tissue
      - increased adrenalgenic activity
      - decreased catabolic activity
      - faster recovery/tissue repair
      - reducion in fat deposits
      ANABOLIC (NON-ANDROGEN RECEPTOR MEDIATED EFFECTS)
      - increase muscle mass
      - increased immune fuction
      - male pattern fat deposits
      - reduced body fat
      - increased electrolyte retention
      - increased hemoglobin and red blood cell count
      - increased calcium deposits in bones
      - increased nitrogen retention
      - increased protein synthesis
      - decreased catabolic ration
      4. Test works really well. Study after study confirms it. Test adds muscle, burns fat, and does all sorts of great things. It is the king.
      Typical doses are in the range of 200-1000mg/week (with HRT users simply looking for better quality of life at the low end and experienced bodybuilders at the high end) wich is the dose for cruising.
      The blasting dose is much higher but as previously mention it will be covered in the shot cycle section because that's really what it is.
      SECONDARY COMPOUNDS
      The reason for adding secondary anabolic compounds is to:
      a) increase the total adrogens in the cycle without increasing the specific sides of test, the primary compound...users will reach a point where their tolerance for the sides from test outweigh the benifits of increasing the test dose, at that point adding other compounds allows the users to take in more total androgens without an equal increase in sides.
      b) change the anabolic/androgenic ratio to acheive different goals
      c) add unique characteristics to the cycle inherent in certain compounds such as healing of joints, increasing libido, increasing hunger, or increasing blood volume
      Secondary steroids that are well suited to longer cycles are:
      - Equipoise and Deca due to their long half life, synergies with test, and low adrogenic/estrogenic side effects. Both provide anabolic properties (compared to increasing the dose of Test) such that they yield additional mass/strength gain without adding strong androgenic/estrogenic sides.
      - Masteron Enanthate or Primobolan due to their long half life, synergies with Test, hardening effect, and effect on Sex Hormone Binding Globulin (SHBG) and estrogen conversion. Both povide androgenic properties with no water weight gain or estrogen issues.
      1. Equipoise (a 1,2 double bond derivative of Test) is roughly equal to Test in terms of anabolic qualities but with half the androgenic/estrogenic properties and has a side effect of increasing appetite (which aids in bulking) and EPO (thus blood volume giving greater pumps, vascularity, and improved stamina).
      The reduction in adrgoenic properties and estrogen conversion reduce the need for ancilliaries when increasing overall doses of AAS. Having an Undecylenate ester it doesn't need to be injected often to maintain stable levels (about once every 7 days).
      Equipoise can be run at levels lower than, equal to, or higher than test in the cycle but most opt for levels about 2/3 to 3/4 that of the test. The one main concern with EQ is blood pressure increases due to increase in blood volume.
      From personal experience a dramatic increase in systolic BP was seen which a slight increase in Diastolic BP. Estrogen is still an issue but at half the conversion rate of Test it is only a problem if using very high doses.
      2. Deca (a 19Nor derivative of test) is a very anabolic drug with little androgenic/estrogenic qualities and has a side effect of aiding the joints and immune function. This adds mass and strength without the androgenic/estrogenic sides.
      This makes Deca mild in terms of hairloss, Benign Prostate Hypertrophy (BHP), blood pressure, lipid levels, and gyno (although 19-Nors are able to elevate prolactin levels which may lead to gyno as well).
      Deca converts to Nor-Estrogen which acts much more weakly on the receptors so gyno is less of an issue unless very high doses are used. Nor-Estrogen is believed by many to be the reason for Deca's ability to aid joint lubrication/health while on.
      Deca has also been shown to aid in collegen synthesis and bone density. Deca is commonly used by those who are suffering from previous injury or illness so it makes sense to use it in a long cycle where their will be continuous stress on the joints, bones, and ligaments.
      The Decanoate ester produces stable levels even when only shot once a week and because of it's side effects of improving joint health and immune function it is a great addition to a long cycle where the body will be under prolonged stress.
      Deca does have a very dramatic negative effect on libido due to it's 19-Nor structure (able to activate the progesterone receptor) so dose is typically lower than test at a rate of 1/2 to 2/3 that of the Test and use often restricted to just a portion of the cycle (ending at least 2-3 weeks prior to Test).
      Deca is often combined with Winstrol to offset the progesterone receptor effects it has or to counter the prolactin effects it is combined with cabergoline or bromocrptine...newer treatment seems to be Mirapex (Pramipexole) which I'm not that familiar with.
      3. Masteron Enanthate (a DHT derivative) binds strongly to the Androgen Receptor. Like other DHT compounds it adds muscle hardness/density and aggression without water retention or estrogen issues.
        DHT has a stronger affinity for SHBG and the aromatase enzyme but will not convert to estrogen once bound leaving it inactive. This means it will leave more unbound Test in the system which provides a boost to libido and will also intercept a good deal of the aromatase enzyme before it has a chance to convert Test to estrogen so it actually acts as a weak anti-estrogen.
        It also adds lean tissue without any water retention so a user after a lean look will benifit from adding it to the stack. The drawbacks of Masteron are it's strong androgenic sides - negative effects on hairloss (MPB), hairgrowth on the body, and growth of the prostate (BPH) although many believe the last to be more a culprit of estrogen than DHT. Either way these symptoms may become an issue with long term use.
        Typical dose of Masteron Enth in a cycle is 200-600mg/w and needs to be shot at least twice a week to keep levels stable. Many users find the benifits begin to diminish over 400mg/w. From my own experimentation I have found over 300mg/w to give too much tightness in the muscles which negatively impacted performance but all users are different. Generally levels run are equal to or lower than Test.
        4. Primobolan is another DHT derivative that is well suited to long term use. It is very similar to Masteron structurally and has similar actions. Because of it's structural differences it has a few unique twists. It has a lower rate of andrgenic side effects and is generally considered milder on the system in terms of suppression.
        It has also shown a positive effect on the immune system. The drawbacks are that doses need to be slightly higher to see good results and the cost is typically extremely high which makes long term use very very expensive.
        Typical dose of Primobolan in a cycle is 300-800mg/w and needs to be shot at least twice a week to keep levels stable. Results in the higher range have shown much better results.
        Primo dose can be higher, equal to or lower than that of Test however if a very high dose of Test is combined with a low dose of Primo the effects of the Primo may become hard to notice or become nullified due to binding with SHBG. For this reason many users will opt to use Masteron over Primo in a cycle due to cost.
        ANCILLIARY COMPOUNDS
        Ancilliary compounds used are for combating side effects:
        1. Estrogen causing gyno or water retention
        - Arimidex (AI...~50% reduction)
        - Aromasin (AI...~85% reduction)
        - Letrozole (strong AI...~98% reduction)
        - Clomid (SERM...weakly blocks the E receptor but does a good job of stimulating LH and FSH)
        - Nolvadex (SERM...strongly blocks the E receptor and does a good job of stimulating LH and FSH, also has a positive effect on lipid levels)
        2. DHT side effects such as hairloss and BPH
        - Finasteride/procepia/proscar (DHT conversion blocker...note this just blocks the conversion of test based androgens to DHT by reducing type II 5 alpha reductase enzyme, it will not block injected DHT based steroids)
        - Dutasteride/avodart (DHT conversion blocker that blocks the type I and II 5ar enzyme)
        3. High blood pressure
        - Ace inhibitors
        - Beta Blockers
        - Dieuretics
        4. Prolactin side effects
        - vit B6 (some assistance but weak)
        - Cabergoline
        - Bromocriptine
        - Mirapex
        5. Progesterone
        - Winstrol
        6. Nut Shrinkage
        - Human Chorionic Gonadotropin (HCG)...this is an artificial way of keeping your nuts up without your body's natural Folicle Stimulating Hormone (FSH) or Leutinizing Hormone (LH) which get shut down from gear.
        It is a peptide hormone produced during early pregnancy...it has an effect of stimulating the lydig receptors in your nuts which tell them to grow and produce testosterone. There is a negative feedback in this process and the lydig cells can be downregulated so it's use needs to be minimal.
        These side effects are dependant on the genetic sensitivity of the user and dose of AAS so their use varies.
        Here is a general guideline I pulled off Elite Fitness
        hCG Dosing Guidelines
        - Human Chorionic Gonadotropin -
        For each cycle length the first one listed (1) is for low dose HCG throughout/on-cycle (Preferred method)
        The second line (2) is for hCG during last few weeks only of the cycle (only if hCG was NOT used during cycle)
        1-6 week cycle
        (1) No hCG needed
        (2) No hCG needed
        8 week cycle
        (1) 250iu every 4 days* from week 3-8
        (2) One 1000iu shot per week for 2 weeks with AI? taken daily
        12 week cycle
        (1) 250iu every 4 days* from week 3-12
        (2) One 1000iu shot per week for 3 weeks with AI? taken daily
        16 week cycle
        Take a 2 week break
        250iu every 4 days* from week 11-16
        * Every 4 days = Shoot on Monday, then on Friday, then on Tuesday, ect.
        ? AI - Aromatase Inhibitor (While taking 1000iu shots, I recommend 10mg/ED of Aromasin or .5mg/ED Arimidex to keep estrogen in control. Discontinue 4 days after last hCG shot.)
        If you are doing the on-cycle hCG protocol it is important to discontinue hCG 2 weeks prior to AAS clearance. Therefore, when you officially start PCT you will be clean of all AAS's and will be 14 days from your last hCG shot. This allows your testes to become re-sensitized to the body's LH signal from the brain, making for a quick recovery of natural testosterone production as soon as the steroids and hCG clear the system. This is another reason why on-cycle hCG is superior, because it allows you to start recovering as soon as PCT begins.
        If you aren't doing hCG on-cycle, then use hCG according to the last few weeks guidelines, and start it 4-5 weeks before the AAS's are expected to clear the system (Or as soon as possible if you are already past this point).
        FAT LOSS/METABOLISM/HUNGER
        1. Clenbuterol/Albuterol - powerful fat burner that also has strong anti-catabolic effects, so it works very well in a fasted state (such as a pre-contest diet). It is a BETA receptor antangonist like most other fat burners and a bronchodilator (think asthma medication).
        Clenbuterol is typically taken in doses which pyramid up to and down from 100-120mcg/d but use will be restricted by tolerance (users will get cramps and jitters if personal tolerance is exceeded). For this reason the pyramid up must be very gradual.
        After 2-3 weeks receptors begin to get downregulated (and may be permenantly effected) so it is best to cycle this no longer than 2 weeks on with an equal or greater period off. Use can be extended (in terms of effectiveness) with things like Zatiden or Benadryl which upregulate/clear the Beta receptors.
        Personally I would just run Benadryl during off weeks if I ran it at all. Clen has been shown to enlarge the cardiac muscle so many people avoid it and I would recommend the same to all but professional bodybuilders who are doing this for a living.
        Albuterol seems to have fewer negative sides (adrenal fatigue, enlarged cardiac muscle) so it is the drug of choice for a lot of people. Dosing with Albuterol is somewhere between 15-20mg spread through the day as it is fairly short lived in the system.
        With either clen or albuterol the fatloss is still very dependant on proper diet and exercise. They are really just a tool to tweak and already good formula, not a shortcut to success for a bad formula.
        2. DNP - I am listing this because it out there and does work but I won't go into it because I think it's pretty dangerous and do not advise using it. We'll post on this subject later
        3. Ephedrine, Caffeine, and Aspirin (ECA stack) - these have been arround a while and talked about to death so I will just list them and say that they increase fat burning and blunt hunger. Their use is cycled as they will also downregulate the beta receptors and lose effect after time.
        Though safer than Clen/DNP they can still cause permenant downregulation if not used correctly.
        4. Thyroid Hormone/Hormone pre-curser (T3/T4) - This is synthetic thyroid hormone and it's pre-curser. Thyroid hormone has a direct effect on metabolism (the rate at which calories are burned for energy) so supplementing with them will amp up the calorie furnace.
        I won't go into much detail on this either because this is a newbie guide and these should really only be used by very experienced bodybuilders (and possibly not even then) but I will say that they will increase fat burning and muscle building because extra calories are being mobilized. It can also burn muscle by mobilizing too many calories so it is often used with AAS and or Clen which seems to have muscle sparing properties.
        It is synergistic with Clen because of Clen's effect on how energy is used in the body. There is a strong risk of suppressing natural thyroid levels (permenantly) and having to stay on the medication for life so it must be taken in a pyramid protocol and only used for a restricted period.
        Unlike Clen where the pyramid up is most important with T3/T4 the most important portion is really the pyramid DOWN portion or taper off to gradually return the thyroid to normal functioning.
        5. HOT-ROX or other legal fat burners - basically most of them act in a similar manner to the above (activating the Beta 2 receptors to increase metobolism and increase fat burning, and have an added compound to blunt hunger) but do so with legal compounds and/or natural extracts.
        Their use varies depending on the product and should be follwed exactly. Like ECA they are often cycled because of downregulation.
        RonnyT
          INSULIN
          Insulin causes glucose/nutrients to be transported from the bloodstream into cells in the body. For this reason it is very anabolic. It is naturally occuring in all of us and is the body's response to food.
          People's insulin response varies depending on a number of different criteria and play a major factor in how your body uses food as fuel (stores it as fat or shoves it in the muscles as glycogen).
          Diabetics insulin/insulin response doesn't work properly which is why they need to take insulin shots or closely regulate blood sugar. When combined with steroids it will cause growth to occur at a very rapid rate.
          Think of the steroid as a worker that is trying to build a house, the house is the muscle cell, the insulin is a truck that is going to help transport more bricks to build a house with, more bricks mean a bigger house is built faster...this is really oversimplified but this is a newbie guide so that is about all the detail I am going into.
          Insulin use in bodybuilders is usually in the area of 10iu/d taken in regular intervals through the day with food (large doses of protein and carbs), usually after training has taken place.
          If insulin is taken without sufficient glucose in the blood then the user will go hypoglycemic then possibly pass out, go into a coma, and die. For this reason I would never recommend insulin to anyone who is not a professional bodybuilder with medical supervision from a licenced doctor.
          THIS IS NOT SOMETHING YOU WANT TO FUCK WITH. Some of the guys on this site and other sites have experimented with insulin and I am pretty sure they will all agree that it is not smart for a newbie to use it.
          Again this is something I am posting just so you know what it is and why you don't need to worry about it at your stage of development.
          OTHER GROWTH PEPTIDES
          Another important component of long cycles are Peptides. Specifically HGH, IGF-1, and possibly MGF.
          Because of their effect on satellite cells they are a great addition to long cycles where there is a prolonged period of use and therefore ideal circumstances for hyperplasia (creation of new cells). My understanding of these peptides is pretty basic but it goes as follows.
          1. HGH - increases IGF-1 and therefore satelite cell activation in muscle tissue and cartilage growth in the joints. It also assists with protein synthesis, endurance, skin quality, vision, and lipolysis (fat being broken down and used as energy).
          Anecdotal evidence from experienced users is results in terms of muscle growth and fatloss seem to be best when run over long periods (greater than 6 months).
          The negatives of HGH long term high dose use is of course the growth of organs specifically the intestines which give the HGH gut look and the growth of bones which can give acromegaly (the caveman look).
          The typical dose for HGH varies depending on your goals.
          For life extensionist and HRT users the dose is around 1.0-2.5iu/d run in the morning when natural levels are already high so the negative feedback is reduced. The dose is taken 5 days on and 2 days off to give the system a break. Shot are usually taken Subqutaneously (in the fat under the skin) to give a longer/slower release.
          For bodybuilding purposes the dose is around 4-10iu (some as high as 20iu+) run either ED (5 on, 2 off), EOD, or E3D. Experimentation is still ongoing but it seems using a larger amount per day but doing so fewer days is looking like the way to go. By taking multiple shots a day the daily dose can be increased (as there is a tolerance factor...many users can't use more than 2iu at a time without swelling of the hands and feet). Taking the shots Intramuscularly (IM) or Intravienously (IV) is a faster way to release the drug which results in less negative feedback from Somatostatin. Same reasoning for the EOD or E3D schedule the negative feedback from Somatostatin is reduced.
          Ideal times to shoot are:
          - early AM when levels would already be high
          - pre-training to cause mobilization of fat stores
          - post training to induce growth when damage has occured to the muscles and the body is primed for growth (usually also combined with high protein/high carb shake).
          One negative with HGH is decreased insulin sensitivity due to over stimulation of the receptors. Combining use of HGH with multiple daily administrations of Metformin (except post workout) to slow the release of glucose in the system from carbs will help to reverse this effect and increase insulin sensitivity.
          2. IGF-1 - increases satelite cell activation in muscle tissue, protein synthesis, and cartilige growth. Mostly the same reasons for taking HGH but without the fatloss benifits. Typical use is post workout in doses ranging from 20mcg to 200mcg. It is injected intramuscularly and usually done bi-laterally (ex half in each biceps muscle).
          IGF-1 will cause a negative feedback loop for endogenous HGH production so using it on an EOD schedule helps to reduce suppression. IGF is often combined with exogenous HGH for this reason.
          High doses of IGF will definitely show negative effects in terms of organ growth so the dose is usually restricted to about 50mcg or less per injection. Basically you want to inject enough that it will bind to all the available muscle cells you have just upregulated from lifting but not enough that you are flooding the bloodstream and ending up with it in the organs like the intestines. Less is more with this drug.
          3. MGF - there really isn't enough evidence on MGF yet to speak on it with any assurance of an ideal protocol or even really a solid understanding of it's effects but here is some info taken from another post that gives a pretty good understanding of the theory:
          MGF is a splice variant of the IGF produced by a frame shift if the IGF gene. MGF increase the muscle stem cell count, so that more may fuse and become part of adult muscle cells. This is a process required for adult muscle cells to continue growing.
          Why PEGylate MGF?
          MGF exhibits local effects in skeletal muscle and without modification is not systemic (can't travel through the body). The problem with synthetic MGF is that it is introduced IM and is water based so it goes into the blood stream. MGF is not stable in the blood stream for more than a matter of minutes.
          Biologically produced MGF is made locally and does not enter the bloodstream and is short acting so stability is not an issue. By PEGylating the MGF we can make synthetic MGF injected IM almost as efficient as local produced MGF.
          Typical protocols so far are using MGF with IGF-1 to replace depleted satelite cells in a manner where about 100-300mcg of PegMGF is used once a week (or 50-150 is used 2 days a week) with IGF-1 being run the rest of the week.
          POST CYCLE THERAPY (PCT)
          Post cycle therapy is used to return to normal function of endogenous testosterone (your own that happens in your balls). It obviously isn't needed with the continuous cycle but absolutely critical with all other cycles. There are two basic approaches for PCT.
          1. Test Taper.
          Tapering is a standard form of cessation of drug therapy in medicine. It stand for gradually tapering down your doses like from 600 to 400 to 200 to 100 mg/week.
          We do it with corticosteroids, we do it with opiods, and other drugs to avoid withdrawal symptoms.
          This is the reason for tapering - to avoid the worst of withdrawal - the hormone crash. The body gets used to the drugs and adjusts. Removing the drugs too quickly will cause side effects. Withdawal of steroids will cause achne, can cause depression which is also related to loss of motivation, loss of libido, and loss of confidence. Yes recovery in full of the hpta may take longer, but it will be easier and healthier, both physically and mentally for the user.
          The basic pricipal is that you are slowly returning the body to normal but holding exogenous test use at baseline (natural) levels and then slowly dropping below that so that the body can adjust. As the levels of exogenous test drop the levels of endogenous test compensate until the body is returned to normal.
            2. HCG/SERM.
            Using HCG to artificially bring the nuts up and then using a SERM to increase LH and FSH levels to keep them going.
            The HCG is either used:
            - Throughout the cycle at a maintenance dose of 250iu (E3D to E4D)
            - In higher doses in the final few weeks of the cycle (4 shots spaced 5 days apart) of aprox 3000iu, 3000iu, 1500iu, and 1500iu is the classic manner of doing things...the dosing guideline posted above in the section on HCG is a little more up to date and would probably be a better one to follow. Remember that the final weeks of the cycle are judged by when the esters are clear not when you are taking the final shots (ie. if your gear is enth it takes about 2 weeks to clear after your last shot).
            This is then followed by 3-4 weeks of SERM use, either:
            - Clomid at about 200mg first day, 150mg/d next few days, 100/mg/d for the next week, and 50mg/d for the last 2 weeks
            - Nolva at 80mg first day, 40mg/d for the first week after, and 20mg/d for the last few weeks.
            This way you are taking the SERM when the gear is pretty well out of your system (all that remains is supraphysiological or below normal levels). There is no point to taking a SERM when you have above normal levels in your system (unless you are trying to stop gyno) because you will still be suppressed strongly and it won't increase LH/FSH.
            PUTTING IT ALL TOGETHER
            So what would a TRT and a Very Long Cycle look like? Here are a few examples (I am not saying you should do this, it is just a basic roadmap to show how it works)
            NOTE: W X-Y means starting the begining of week X and ending at the end of week Y
            TRT (continuous)
            Test Cyp 150mg E4D
            Adex 0.025mg E4D
            HGH 2iu ED (early AM - Mon, Tues, Wed, Thu, Fri)
            EXPERIENCED
            W 1-20 Deca 200mg E4D
            W 1-36 Test Cyp 500mg E4D
            W 1-36 Mast Enth 200mg E4D
            W 1-39 Adex 0.5mg EOD (tapered in last 2 weeks to 0.25 EOD)
            W 1-52 HGH 4iu EOD, 40mcg IGF-1/D EOD (post workout)
            PCT
            W 37-42 Test Cyp 50mg 2x/w
            W 43 begin dropping each shot by ~5mg until you reach zero
              This needs a sticky
              http://napsgear.net/?ref=276
                Thanks Ronny, some time it seems like the new guys don't believe us or just don't want to listen.
                  Ill second that. I refuse to spoon feed them any more. If they have to ask what to run, theyre not ready
                  "I COUNT HIM BRAVER WHO OVERCOMES HIS OWN DESIRE THAN WHO CONQUERS HIS ENEMIES, FOR THE HARDEST VICTORY IS OVER SELF"
                  "SUCCESS ISN'T ALWAYS ABOUT GREATNESS. IT'S ABOUT CONSISTENCY. CONSISTENT HARD WORK GAINS SUCCESS. GREATNESS WILL COME"
                    Damn Ron you should get that stuff published man. Also just post a random reply to this every now and then just to keep it on the NEW tab. Good stuff
                      He did - http://www.amazon.com/Underground-AN.../dp/0967930499
                      I only wish I could read :{
                      ODB
                        Great thread Ronny!
                          I have like 4 kindle books.....this is one of them!
                            Thanks
                            I have printed this out and will always reference to it in the future. I just posted the "first time user thread" and I don't need it now.
                            Thanks Man
                            [/COLOR]"The Iron never lies to you. You can walk outside and listen to all kinds of talk, get told that you're a god or a total bastard. The Iron will always kick you the real deal. The Iron is the great reference point, the all-knowing perspective giver. Always there like a beacon in the pitch black. I have found the Iron to be my greatest friend. It never freaks out on me, never runs. Friends may come and go. But two hundred pounds is always two hundred pounds."
                            Henry Rollins
                              excellent complex read... as allways Ron
