ESTER weight + Effects on Dosage
  • ESTER weight + Effects on Dosage
    Milligrams below are the estimated amount of active hormone per 100mg of hormone and ester.
    Boldenone base: 100mg
    Boldenone acetate: 83mg
    Boldenone Propionate: 80mg
    Boldenone Cypionate: 69mg
    Boldenone Undecylenate: 61mg
    Clostebol Base: 100mg
    Clostebol Acetate: 84mg
    Clostebol Enanthate: 72mg
    Drostanolone Base: 100mg
    Drostanolone Propionate: 80mg
    Drostanolone Enanthate: 71mg
    Methenolone Base: 100mg
    Methenolone Acetate: 82mg
    Methenolone Enanthate: 71mg
    Nandrolone Base: 100mg
    Nandrolone Cypionate: 69mg
    Nandrolone Phenylpropionate: 63mg
    Nandrolone Decanoate: 62mg
    Nandrolone Undecylenate: 60mg
    Nandrolone Laurate: 56mg
    Stenbolone Base: 100mg
    Stenbolone Acetate: 84mg
    Testosterone Base: 100mg
    Testosterone Acetate: 83mg
    Testosterone Propionate: 80mg
    Testosterone Isocaproate: 72mg
    Testosterone Enanthate: 70mg
    Testosterone Cypionate: 69mg
    Testosterone Phenylpropionate: 66mg
    Testosterone Decanoate: 62mg
    Testosterone Undecanoate: 61mg
    Trenbolone Base: 100mg
    Trenbolone Acetate: 83mg
    Trenbolone Enanthate: 68mg
    Trenbolone Hexahydrobenzyl Carbonate: 65mg*
    Trenbolone cyclohexylmethylcarbonate: 65mg*
    The esters and release rate are important to know for Half Life of AAS, in case ur getting tested, doing shows and for starting PCT.
    Also important knowledge for dosing and stacking - u want complimentary stacks.
    They also effect the true dosage of the AAS - this info was posted by the illustrious "SAM";
    steroid ester weight
    -every ester isn't created equal. just because you're injecting 250mg/ml, doesn't mean you're getting 250mg/ml
    Esters not only effect release times but also the potency of the Testosterone as esters make up part of the steroid weight. This must be taken into account when calculating dosages. The longer the release time the less free hormone. For example propionate is about 15% more potent mg. for mg. then enanthate so 500mg of propionate would equal about 575 mg. of enanthate. The following chart illustrates the free base equivalents for several compounds.
      very interesting ODB.....!!
      test
        BINGO.. simple calculations .. HEY I WANTED TO SAY THAT!
          That's why I like short esters better. Short acting esters allow better control of keeping blood levels of any AAS constant. You can get blood levels up high in just one day and keep the levels high. You can also keep blood levels high all the way up to the day the AAS clears your system
