Oral Turinabol
Oral turinabol is an oral steroid which contains 10mg of the hormone Chlorodehydromethyltestosterone. Oral Turinabol, as it is often called, was first discovered in East Germany in 1962. The steroid became very popular due to its high anabolic properties while being a fairly low androgen. The anabolic activity of oral turinabol is somewhat lower than that of dianabol as well, but it does maintain a much more favorable balance of anabolic to androgenic effect. This drug is considered to be the main component of the famous East German doping machine, in which thousands of Germanys Olympic athletes were secretly given steroids in hopes of dominating the Olympics. In the 1990s the company that marketed oral turinabol for prescription use discontinued the manufacture of this drug, due mainly to controversy over sports doping. Currently, there are no prescription preparations of this drug in existence, however the drug is still available today on the black market from underground manufacturers.
Oral turinabol is in the same family of steroids as methandienone. The results of this drug are often reported by bodybuilders as being similar to those of D-bol, yet without any of the bloat. Bodybuilders have nicknamed the drug T-bol due to this. The lack of bloat is due to the fact that oral turinabol doesnot aromatize in the body, and therefore no estrogen related side effects become present. Users of this steroid often report very good gains in strength along with a slight gain in quality muscle mass. T-bol is often used as a jump start to a cycle. Here the quick acting effects of the oral allow the bodybuilder to start experiencing gains and pumps early on, while the injectables being used in the cycle have more time to take effect. Oral turinabol is a very versatile steroid and can be used effectively in both cutting and bulking cycles. It stacks well with virtually all compounds, and is also effective at lowering SHBG in the body, thus making the other compounds, such as Testosterone, even more effective. Oral turinabol is also commonly used as a bridge in between cycles. Here a low dose of the drug (10-15mgs a day) will be used in between cycles in order to prevent a total crash and to help the bodybuilder preserve gains made from the previous cycle. Oral turinabol is fairly androgenic and all of the androgenic side effects are possible when taking this drug. Androgenic side effects can include things such as oily skin, acne, and increased growth of facial hair. In women androgen can cause masculizing side effects such as deepening of the voice, clitoral enlargement, and the growth of facial hair. T-bol is a C-17 oral, and therefore can be toxic to the liver in higher doses for extended periods of time. Because of this, it’s recommended that users keep doses in reasonable ranges and try to limit their cycles of this steroid to no more than 8 weeks at a time. Users may also wish to run some sort of liver protecting agent along side of this drug such as milk thistle or Liv-52.
Men would take the drug in dosages of 15-40mg per day, depending on goals, for a period of 4-8 weeks. Women athletes also find favor with oral turinabol and would often fine a dosage of 5mg per day for 4-6 weeks to be sufficient for producing desirable results.
