5 Things You Must Know About Tren
You've just completed your first Testosterone cycle and are eager to begin your second cycle with Trenbolone. Or maybe you've just been administered TRT and want to try a few things out. Tren appears to be almost perfect…
This is something we've heard so many times that it no longer surprises us. Any fitness fanatic or athlete who has used AAS will undertake a Tren cycle at some point. It can't be avoided. It's the unadulterated truth.
So, if you're reading this and you've used Testosterone or Winstrol and you've promised yourself that you won't cross this line, here's the problem. Don't deceive yourself. You're going to perform a Tren cycle. Period.
Not that we don't like Tren. It's fantastic. We've gone through several rounds ourselves. It is the world's most powerful AAS. There aren't many substances with a 500 anabolic rating. We understand everyone’s love for it.
However, there are some consequences of the Tren Cycle that you may never be able to reverse. Things that have the potential to go wrong indefinitely. As a result, it is critical that you complete your first Trenbolone cycle correctly.
Here are the five most important suggestions we can make.
#1 - Recognize the differences between esters.
Trenbolone is a 19-nor injectable anabolic hormone that was developed for usage in animals. It was allowed for usage in humans for a short time before being withdrawn off the market. If you want to get Trenbolone, your only options are to make it yourself or buy it from a UG lab or online pharmacy.
Trenbolone Acetate, popularly known as Tren Ace, and Trenbolone Enanthate, generally known as Tren E, will be available. Technically, there is one more ester: Trenbolone Hexahydrobenzylcarbonate (aka Tren H or Tren Hexy); but for today we’re going to focus on the main superstars: Tren Ace and Tren E.
If you search up information on which Ester to choose on the internet, you might be fed bro science that Ace can give you one look while Enanthate gives you another. That's complete nonsense. Trenbolone is all it is. The hormone remains unchanged. It is the ester that accomplishes it.
You can make an informed decision if you understand the differences between the esters.
Trenbolone Acetate
Trenbolone Acetate is a faster-acting form of Trenbolone with an ester weight of 87 percent. This means that the Trenbolone Acetate in a 100mg vial contains 87 percent Trenbolone. If you want to receive a true 100mg dose, inject at least 115mg of Tren Ace.
Pros
Half-life is very short (2-3 days)
Because of the tiny change in ester weight, you'll notice it sooner. This is what you should use if you want speedy results.
It’s roughly 10% more effective than Enanthate.
Cons
More expensive than Enanthate.
To keep blood levels normal, you must pin every day.
The cost of injections, the possibility of scar tissue, and so on are all part of everyday pinning.
With a 70 percent ester weight, the Enanthate ester is the slower acting form. This means that Trenbolone Enanthate is 70% Trenbolone in every 100mg vial. If you take 100 mg of Tren E every day, you'll need to inject 130 mg of Tren E.
Pros
Cheaper than Tren Acetate.
Fewer pins are required. Every third day, the majority of people pin. Some people only pin once every four days, which saves money and lowers the danger of scar formation.
Cons
This is a slower-acting variant, so it will take a bit to kick effect.
It's possible that it'll be 10% less effective than Tren Ace.
#2 - Your Dose
The best Trenbolone dosage for you will be determined by two factors.
1. The steroid's quality when you buy it.
2. Your reaction to Trenbolone will be one-of-a-kind.
If your gear is genuine, you should begin with a very low dose to see how you react to tren. Don't let what you read on the internet or on message boards influence you. What may have been an effective dose for someone else may be ineffective for you.
On the other hand, even the smallest amounts may cause your body to react negatively. Trenbolone has some of the worst negative effects of any drug.
Start with 50mg/ED of Tren Ace if you're new to it. It will keep your levels constant, and 350mg per week is an excellent dose. This will give you a good understanding of how the chemical affects you.
#3 - Set your Testosterone dosage.
Testosterone must be used in conjunction with Trenbolone. There are several schools of thought about how much Testosterone you should run with Tren. However, there is only one correct quantity, and that is the amount that YOU require.
That is contingent on your reaction to the substances. Some people only require 25mg of Test Prop ED. By any standard, this is a minuscule dose. What's more, guess what? It's effective.
The majority of the literature you'll come across will suggest taking at least 500mg of Test per week in addition to Tren. That's a good dose for some people, but it might not be necessary for you.
The only piece of advice we can provide you is to start small. Start with 50mg/ED if you're using Test Prop and work your way up or down depending on how you feel.
#4 - The Side Effects
Trenbolone will catch you off guard, like a lion hunting a gazelle in the African savannah, and rip you to shreds if you don't prepare yourself.
Hair Loss: If you're going to lose your hair anyway (MPB), this stuff will completely destroy it in a matter of weeks.
Blood Pressure: Be prepared for a rise in your blood pressure. Even a simple flight of stairs will leave you gasping for oxygen. Keep an eye on it and, if necessary, take corrective action.
Acne: If you already have acne, this will exacerbate it. Otherwise, you'll be OK.
Libido: This is where balancing your testosterone/Trenbolone dosage becomes critical. You'll feel horny, powerful, strong, mean, whatever you want to call it if you get your test dose right.
Sweating: You'll be sweating like a pig for the duration of the cycle. Night sweats can be debilitating.
Mental Aspects: The Tren is working great if you feel more aggressive in the exercise. It's crucial to break the pattern if you're experiencing paranoia and hallucinations.
Gyno: It is impossible to produce gyno. Most of the time.  However, it can induce an increase in prolactin levels. Keep Cabergoline on hand at all times.
#5 - Never Brew It, Always Buy It
Don't be tempted to save a few dollars by making Trenbolone at home, especially if this is your first cycle. Save time and money by purchasing high-quality gear. I highly recommend NAPSGEAR.ORG for all of your cycle needs. Naps Gear is an online pharmacy that has almost everything you need pre, post, and during any cycle, and it sends everything for third-party testing for quality.
